Water keeps filling and overflows when on any cycle.
Is this a timer problem
Comment posted on Jan 21, 2008
The chamber on the side of the outer bowl with the tube attached was plugged. I removed the hose from the chamber and used an Air Hose and blew out the dirt. This solved my problem.
thanks!
not normally. Sounds like the level pressure switch is not operating.
There is a chamber on the side of your outer bowl...this has a tube attached heading off to the pressure switch.
Check tube for chaffing; check for blockage in chamber and tube assembly;
if none of the above could be the pressure switch this is thou.
Was this solution helpful? Show your Appreciation by rating it:
