Hello!
I wanted to print on a thermal paper (fax roll paper) via Samsung ML-1610 but the my problem is that the background is black. when I use the normal paper, the above problem doesn't occure so I am sure the cartridge have no problem.
would you please help me how can I fix the problem. Does it need special setting in printing?
Thank you.
farshad Kooshesh
Laser printer CAN'T print on thermal papers! Lasers printers use a heat source to fix the toner in the paper, and that same heat source turns the thermal paper black. In one word, you CAN'T use that kind of paper unless you disable the heat source, and in that case you won't be able to print on normal paper and the toner won't fix on any kind of paper!!!
I have not drivers of samsung ML1610-XSG laser printer
