Question about Hitachi 53UWX10B 53" Rear Projection Television
Green lines along top of Hitachi 53UWX10BA
Just started getting green lines on top of screen on model 53UWX10BA. The color green also seems to be shadowing on screen.
  • BrianE Jan 08, 2008
    Having a distroted picture at the top, middle and sometimes bottem of the screen. When I run the "Magic Focus" feature the blue and red look fine the green is distorted and fuzzy. Running the magic focus also seems to help the distrotion problem slightly but the top of the screen always has a focus distortion to it. Can someone help. I do not know the model number of the TV but it was puchased in 2002 and looks just like the 53UWX10B.
    President:
  • 4,402 Answers
Convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 09, 2008
Hitachi projection tv 53uwx10ba - the Convergence ICs were replaced. When the PDKP bridge between convergence board and 2nd board is plugged in, it makes a noise. Kept that unplugged, the picture is...
Did set have this problem before you replaced the STKS?
I know these sets very well. If problem is different in any way from before you replaced chips.......double check all soldering or one of the new chips may be defective.
The more you tell me the better I can help.
regards, SD TECH
Aug 18, 2010 | Hitachi 53UDX10B 53" Rear Projection...
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Nov 29, 2009 | Hitachi 43FDX01B TV
Green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Jun 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I HAVE A HITACHI PROJECTION COLOR TV. MODEL 53UWX10BA 52". I JUST MOVED THE TV BY TRAILER FROM ONE TOWN TO ANOTHER, ABOUT 25 MILES, WHEN I PLUGGED THE TV BACK IN AND HOOKED UP THE CABLES, THE PICTURE WAS...
Replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Jan 27, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi Mo# 53uwx10ba double image
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
I would change both ICs STK392-110 and also the 3.3ohm 1 watt resistors and the 1.8 ohm 1 watt you would need 2 of each resistor. Then your convergence would be new again. You can get replacement ICs and resistors at the following link with free shipping and free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jul 01, 2008 | Televison & Video
Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
280 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
