Question about Roper REX4634KQ Electric Dryer
Roper mod REX4634KQ1- Location of BOTH thermal fuses.
I had to run new wiring from pole to mobile home due to the hurricane jerking wires out under trailer. Before the hurricane (Rita) it would run but would not heat up. I am finally back in the trailer and find that it will not even start. I have checked the power to the dryer and every thing is fine. I read the answers to previous questions and still need to check the fuses. I know where one fuse is (bottom left) near the blower fan, but not the other. Any help is appreciated.diagram of both fuses would help.
Also, can I get a repair manual if you have it and if not where can i get one.
  • mfontenot Jan 02, 2008
    Thank you for reply. My husband said he checked the fuse by the blower and the theromstat. The fuse is fine but not the thermostat. Could the thermostat be the problem for not starting?
    He located the fuse by the heating element and found that it is broke off. Going to get a new fuse and get the parts place to check the thermostat. I hope that is the problem. Thanks for you help.
  • 66 Answers
One is by heating element. i can fax you the diagram if you give me fax#
Posted on Jan 02, 2008
  • sohail anjum Jan 02, 2008
    stating mean is not trun on
My truck has a 4 wire plug plugging into a 4 plug with 5 wires to trailer. how do you wire trailer wires to adapt to plug that plugs into the plug with 4 wires
If the trailer has electric brakes that are powered by a separate battery, you use a 4-pole to 5-pole adapter and connect the extra wire to the truck backup light circuit.
4 pin to 5 pin plug for trailer lights The Hull Truth Boating and Fishing...
Aug 12, 2017 | Cars & Trucks
Has a 5 pole socket for trailer wiring
Your terms are inconsistent.
Female 5 pole receptacle on the bike is what you need? You have a 4 pole male plug on the trailer?
You are looking for some sort of adaptor? Please show a picture of both ends, it would help.
May 13, 2014 | 1994 Honda GL 1500 SE Gold Wing
I want to tap into the reverse tail light wiring for a surge brake solenioid,
We at not living in the 1960's
You tap into any of today's vehicle circuits, your
asking for unknown problems
Have you considered you said a solenoid,& do you
know the current draw on that solenoid
Best design a new circuit using a relay & control it with
the back up switch ,if the can handle the extra current
Need wiring diagrams,some math & ohm's law there
Feb 07, 2013 | 2010 Hyundai Santa Fe
I bought a lark enclosed trailer and it is wired with the 7 pole rv plug and my truck has the 6 pole. i changed the trailer end to a 6 pole, matched the same wiring as my other trailers but the lights on...
Normally all trailers are wired the same. What I think has happend is the new plug has been wired in wrong. The Rv Plugs wiring is differnt than that of a flat four and round six. I would look in the box that you got the plug in a make sure the wires are correct. I can't find a diagram work the wiring but I do know that the brown is the tail lights, red is the brake, yellow is left turn, green is right turn, and the blue wire is the electric brakes. there is also a Aux power I think that is a pink or Bigger gauge red wire.
Mar 02, 2011 | Chevrolet Silverado 1500 Cars & Trucks
Bought trailer harness for my trailer all four poles show 4 wires mine has five wires going to trailer lights turn on signals both light up like four ways also no brake lights. made sure all lights were...
try This should help. The 5th wire is a lockout for the brakes that hooks to your back up lights. So when you back up, the brakes won't engauge. Typically white is ground, yellow is left turn, green is right turn, and brown is running lights.
Sep 24, 2009 | 1998 Ford Explorer
I have a 2008 Toyota Highlander with the TO factory option. I installed an aftermarket trailer hitch. Do I just need a trailer light pigtail (to connect to the connector in the rear) or must I also...
I believe the box also is a safety feature in case of a wiring problem from some event, like an accident.
You need a converter to convert the turn signals and brake lights to run off the one bulb on the trailer. A flat 4 pole connector is the usual connection. A 4 to 5 pole converter may also be needed to add the backup light power to disengage the surge brakes while backing up If your trailer has that option. 4 to 5 is not really necessary but it eliminates having to get out and move the connector or insert the brake bypass key.
Aug 14, 2009 | 2008 Toyota Highlander
I can't find the fuse or relay for the trailering harness battery charging circuit. Everything else works fine. The truck is a duramax and has 2 batteries.
In your fuse box under the hood... there are 2 fuses marked pole 1 and pole 2. One of these is the fuse to feed 12 volts to the trailer. The poles are located under a smaller cover just behind the main fuse box under the hood. The wiring may have to be connected to the bolt/post.
Jun 27, 2009 | 2005 Chevrolet Silverado
2003 denali trailer wiring
If your signals & brakes are on 2 different circuits, ( for example a red lens for stop & an Amber for turn.) then you'll need to buy a converter that goes between vehicle & trailer. They're not too expensive at any trailer or RV place. I think some of the autoparts stores stock them now too.
Jun 20, 2008 | 2004 GMC Sierra Denali
Roper REX4634KQ Electric Dryer Logo
570 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
