Question about Kenmore 75944 Gas Dryer
Kenmore gas dryer 110.72512101
My dryer heats up but won't maintain heat throughout the cycle. I have cleaned the lint out of all outlets. ???
  • 4 Answers
Try your pipes at the back,you may have a split
Posted on Jan 02, 2008
My kenmore 5200 series gas dryer won't heat. My
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Aug 28, 2011 | Kenmore Dryers
Heat level in dryer
A dryer usually overheats because of a kink or blockage in the duct work, blockage in the outside wall cap, or because of a defective cycling thermostat. The cycling thermostat tells the dryer when to heat and not to heat. Clean any lint from the inner and outer ductwork. You can also remove the vent from the back of the dryer for a load or two to determine if the clothes dry faster or not. If this doesn't fix it, go ahead and replace the cycling thermostat. Make sure to use the appropriate setting to dry the clothes.
Aug 09, 2008 | LG DLG0452W Gas Dryer
Kenmore dryer will only work on no heat cycle...any other heat cycle will give pf code. md number 417.84092500
The Kenmore H5T is an electric clothes dryer meant for residential use and manufactured by the Kenmore Company, which manufactures a wide variety of appliances for the home, including refrigerators, dishwashers, microwaves, stoves, and clothes washers and dryers. While most Kenmore clothes dryers work well with only basic care and maintenance, certain problems, such as the dryer not heating, occasionally occur. Troubleshooting this issue may solve the problem without the help of a service technician.
  • Ensure that the dryer is properly connected to a working grounded power supply. Confirm that the power cord is plugged firmly into the dryer and the power outlet. Reset household fuses or circuit breakers if necessary.
  • 2 Remove the lint screen from the bottom front of the dryer. Pull off all lint so that the filter screen is clean, and replace the lint screen in the dryer.
  • Run the dryer for 5 minutes on a normal cycle and hold your hand under the outside exhaust hood to feel for air movement. If there is no air movement, turn off the dryer and unplug the unit. Disconnect the exhaust vent and clean out any possible obstructions, such as excess lint. Reconnect and confirm that the vent is not kinked or crushed and preventing proper heated air flow.
  • Ensure the dryer is not in a room or outside with ambient temperatures below 45 degrees Fahrenheit. The dryer will be unable to heat properly if the ambient temperature is too low.
  • Avoid overloading the dryer with too many clothes, which will limit proper heat and air flow in the dryer. Make sure the dryer is not set on an "Air Only" dry cycle, which does not provide heat.
  • Contact an authorized service technician if the preceding steps do not resolve the problem.
  • Dec 20, 2010 | Kenmore Dryers
    Burner ignites for 8 seconds and then shuts off. never heats up. vent clean, lint trap clean, lint screen clean
    Hi, If you have a gas dryer2_bing.gif.
    The most common problem with a gas and no heat is the ignitor going bad...
    Here is a tip that I wrote about that problem...
    Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
    If your dryer2_bing.gif is electric2_bing.gif..
    There could be a number of different problems...
    Check out this tip that I wrote about this problem...
    Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
    Jun 20, 2010 | Kenmore 67082 Electric Dryer
    There is no heat
    Check the exhaust vent tubing throughout. If clogged up with lint the sensor will shut the heating completely off all the time till cleaned
    May 08, 2010 | Kenmore 62602 Electric Dryer
    I have an Kenmore 80 Series Gas Dryer, the heat is not staying on. I've changed the heating element and no change. It heats up for 2-3min then turns off for 3-4min then restarts for 20-40sec. then off...
    How are ya?
    The heating element is supposed to cycle on and off to maintain a set temperature. If it takes too long to come back on again, then the thermistat is malfunctioning.
    Take a temperature probe and stick it in the drum and let it run for a few minutes and note the temperature. Should be consistantly near 90 - 130 degrees. Good luck :)
    Jul 18, 2009 | Kenmore 800 7983 Dryer
    Kenmore dryer starts, then stops. Heated motor smell
    First CLEAN out the lint, not just in the mesh screen, but also by opening up the dryer to check for lint around the motor, and the manifold that connects from the drum to the outlet tube. Open up the manifold, carefully, remove lint, and REPLACE the heat sensor/temperature thermocouple that is on the outside, and has a protruding point into the manifold ($20 or less). If the drum spins when you start the cycle, it is NOT the motor! The burning smell is probably LINT that stuffed into the outlet pipe and manifold.
    I have cleaned the outlet tube, manifold, and areas under/around the drum for my dryer, and my rental properties and "fixed" the problem. If it still turns off, then get the correct replacement sensors and replace them. DO NOT open the heating element. The wires inside are fragile.
    Sep 08, 2017 | Dryers
    Check your igniter coil. It sounds like this part could be going bad. Another possibility is that the thermostat is defective. Some dryers have more than one thermostat.
    Yet another possibility is that your thermal fuse is faulty.
    I would check this webpage for more troubleshooting hints:
    Jan 02, 2008 | Dryers
    Kenmore gas dryer
    lots of people point the finger at the dryer when they have a problem you could have bad thermal cutoffs on the back of the flame tube BUT is your washer spinning properly to remove the majorityof water from the clothes
    Jan 02, 2008 | Kenmore 75944 Gas Dryer
    Kenmore 110.72512101 gas dryer
    Are you getting little or no lint on the lint screen? Are the clothes coming out nearly as wet as they went in, but feel warm? If so, you probably have a blockage somewhere in the vent/duct. Don't just check the back of the dryer, but also check the duct thru the wall and the point where it exits the house (exterior wall or roof). Many times birds will nest in the exterior vents or if they have a screen to keep the birds out it may become clogged with lint. If you have a window nearby try drying a load with the vent hose disconnected from the wall and hang it out the window (you COULD vent it into the house, but you may end up with lint everywhere and a lot of moisture in your house).
    Kenmore 75944 Gas Dryer Logo
    89 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
