Kenmore 75944 / 75942 / 75946 Gas Dryer
Kenmore 110.72512101 gas dryer
posted by cadgeek on Jan 02, 2008
my dryer heats up but won't maintain heat throughout the cycle. I have cleaned the lint out of all outlets. ???
Comment posted on Jan 02, 2008
I have cleaned the dryer lint outlets and also the outlets leaving the house
the burner takes about 30 seconds to light and i have heat for about 5 to seven minutes and then no heat after that
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
Ken-Mo
Rank:Guide Guide
Rating: 82%, 6 votes
Are you getting little or no lint on the lint screen? Are the clothes coming out nearly as wet as they went in, but feel warm? If so, you probably have a blockage somewhere in the vent/duct. Don't just check the back of the dryer, but also check the duct thru the wall and the point where it exits the house (exterior wall or roof). Many times birds will nest in the exterior vents or if they have a screen to keep the birds out it may become clogged with lint. If you have a window nearby try drying a load with the vent hose disconnected from the wall and hang it out the window (you COULD vent it into the house, but you may end up with lint everywhere and a lot of moisture in your house).
Since you say the vent has been thoroughly cleaned then you could have any number of culprits. Most likely either an operating thermostat or (since it says yours is a gas dryer) a weak ignitor. Hard to say without being able to listen to the burner cycle on/off, visually checking the ignitor, and checking the exhaust temperature. Does it make any difference if you use the "timed" cycle? Does the burner seem to take a long time to light or shut off and then never come back on?
Rating Locked! (?) cadgeek has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on kenmore 110.72512101 gas dryer:
I don't want to Accept this solution
Can you Help with these Dryers problems?
Dryers
Trying to replace a broken belt on my ancient Frigidaire...
Dryers
error code E4A on my frigidaire affinity dryer
Dryers
My Whirlpool, LER6620PQ1 dryer will not stop running, nor...
went to get sheet and dropped the sheet in the lint trap...
I've cleaned out all dryer vents includining venting to...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
