Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I have a sharp aquos 1080p HDTV. My xbox 360 is hooked up to inout 1 but the image constantly flickers. i recentley looked on this webpage on how to solve it and found a solution by changing my color system on my remote settings.. one problem its locked.. how do i unlock this??? please help
5 Suggested Answers
SOURCE:
  • 8 Answers
SOURCE: sharp aquos
The screen resolution is determined by the source and not the television.  The source (e.g. a PlayStation 3) will query the television to determine which modes it is capable of and then (normally) use the highest available.
I've not had any problems with DVD players, computers, games consoles not managing to send 1080p so it might be worth checking the settings of the source device to see if there's anything you can change there.
Failing that I'd try and find a friend and borrow something from them that they know is working at 1080p without any problems - if the television still won't go to 1080p then its probably a fault in the HDMI cable or something odd with the television.
Posted on Nov 18, 2007
SOURCE: SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Posted on Jul 09, 2008
  • 10865 Answers
SOURCE: I can't find the owner's/TV manual for Sharp AQUOS
http://www.sharpusa.com/files/tel_man_LC46D43U.pdf
Posted on Jun 04, 2009
bshldn
  • 736 Answers
SOURCE: Sharp AQUOS 52" 1080p 120Hz Flat-Panel LCD HDTV
Press the menu button and scroll over to the setup sub category. Scroll down to reset and press enter. Select yes and then enter. Select yes again and press enter. The television will turn itself off and then back on.
If that basic reset doesn't work call 877-332-7867 to be walked through the no sound troubleshooting up to an INIT. I cannot put the steps for an INIT into print because any wrong move could erase everything from your television.
Posted on Dec 29, 2010
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
Dec 26, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
How do i hook up my xbox 360 to the Sharp Aquos
You have a few options actually. depending on which 360 you have you have at least 3 ways to connect; 4 if you have CDMI cable output on Elite 360. you only need to pick one though. easiest is the plug with one yellow and a red and white. the yellow is the video and the red and white are the left and right audio. You can use the red green blue plugs choice if your tv has that input. in that case the red green blue are the video and you use the other paired red white for audio. You can use the S video connection (the round one that looks like a mouse plug) for video. You can use the HDMI (flat, looks like giant USB slot) for really high quality video. So, basically just use whatever cable you happen to have. If you still have questions, please ask as we will definitely get you hooked up for sure:) farmerbear at FixYa
Oct 14, 2010 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
Tv screen keep going black,
did you check the sleep mode on the tv?
Aug 05, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Aquos screen blacks out with xbox 360 using Component Cables
Downloaded the updated firmware from the sharp website to a usb drive. Placed the drive in the TV and went to the update software option on the TV menu. Since the update, I no longer get the black-outs on the screen. I also put the resolution on the 360 back up to 1080p and it works great, even through the component cables.
Jun 29, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
While playing xbox 360 in 1080p mod, the screen frequently blanks
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
Dec 18, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Just bought, everything coming in at 1080i not 1080p
the xbox 360 does not brodcast at 1080p and no tv channals are in 1080p yet. Blu-ray and HDDVD is the only thing in 1080p yet
Jul 23, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Well I do not know either machine but suspect if the video is old either your video's output is too rough for the TV because:-
It has some age related problem of wear.
The output signal is not quite correct in quality.
There may be a security signal applied on its recording material.
These are some of the issues, videos are very sloppy (by todays standard) but could get away with it with analogue TV's because of wider design variables inherent in that system.
Modern TV,s are less hardware more software driven and as such are critical about errors going to a blank screen as a way of escape an issue they can't resolve (mummy mummy!).
The video may need checking for mechanical or electronic issues, a favourite being power supplies which can generate noise from defective components that disturbe other equipment, or mechanical alignment which changes through wear and time.
You could try conversion to hdmi signal though cheap converters are limited in their method of doing this but might show you if it would work.
Cheap versions are about £10 but have no level controls (contrast, brightness or colour to trim for best picture)
Hope this helps............
Apr 27, 2017 | Televison & Video
Sharp LC=32D43U display capabilities
is the switch set to hdtv on the cables... and are the display settings in the dashboard set to hd
Dec 26, 2007 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
116 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
