You can make multiple copies by loading them print side up into the upper feeder you'd use to fax, then entering the number of copies on the keypad and hitt the copy button for color or black or you may lift up the carriage and place a page on the scanner glass, close the carriage select the number of copies and hit the copy button for color or black
Was this helpful?
Yes
No
Popular Solutions for HP OfficeJet 7410 All-In-One
My Computer doesn't recognize HP devices either a scanner or a the scan function of a...
(More)
My Computer doesn't recognize HP devices either a scanner or a the scan function of a printer/scanner
When the 7410 is plegged in, the On button does not light up. In fact, none of the buttons will...
(More)
When the 7410 is plegged in, the On button does not light up. In fact, none of the buttons will light up. The 7410 starts its boot up mode, but never comes out of it. Depressing the On button has no effect whatsoever. The computer says the 7410 is not connected. What do you expect is the problem?
It seems to be stuck. The HP screen seems to be booting but the on button does nothing. It is...
(More)
It seems to be stuck. The HP screen seems to be booting but the on button does nothing. It is frozen. I have turned it off time and time again to reboot but it does the same thing. Any ideas?
My HP Officejet 7410 All-in-One Inkjet Printer is doing the following: 1) It prints in color even...
(More)
My HP Officejet 7410 All-in-One Inkjet Printer is doing the following: 1) It prints in color even when the document is black and white (using up the color ink) 2) It prints much more slowly than it did originally.
My HP OFficenjet 7410 won't print. I keep resetting it and the screen reads "Error...
(More)
My HP OFficenjet 7410 won't print. I keep resetting it and the screen reads "Error 0x8386ff58" Suggestions?
