sounds like the vent line is clogged with lint clean out the dryer and take the vent line off the back and blow out the line with a leaf blower,check outside and make sure the air is blowing open the flapper
Comments:
Nov 04, 2009
- you could have a bad gas valve,try tapping the valve and see if it works,if it does come on you still have to change valve
error E61 appears on digital screen. dryer does not work at all....... help.... resetting has not...
(More)
error E61 appears on digital screen. dryer does not work at all....... help.... resetting has not helped, technican has no idea......
The dryer starts fine and runs for two minutes, then stops. The digital readout goes from 58 to 00....
(More)
The dryer starts fine and runs for two minutes, then stops. The digital readout goes from 58 to 00. I have heat, the dryer just wont run a full cycle. I have tried disassembling the dryer and completely cleaning it out, with no luck
Hello, My dryer just displays EO1 All the buttons make a beep sound but nothing happens. It will...
(More)
Hello, My dryer just displays EO1 All the buttons make a beep sound but nothing happens. It will not do anything. Thank you. BB
I just had a new GE Gas Super Capacity dryer installed. One hour after it was delivered I went to...
(More)
I just had a new GE Gas Super Capacity dryer installed. One hour after it was delivered I went to use it and it sounds horrible. It sounds like a furnace blower starting and then a clanking noise, then the blower sound will go away for a minute and the clanking diminishes, then it will start all over again. It does heat up nicely, when I have it on air dry I have no noise at all. Very upset they cannot come to look at it for a week. Any ideas? Could the gas line be messed up, since it works so well without the heat on.
