Question about Zanussi FJS1225W Front Load Washer
Zanussi FJS1197 w ashing machine making knocking noises when spinning
Hi I have an 8 year old zanussi fjs 1197 w. I believe the drum bearings are gone as when I spin the drum by hand it makes weird noises. There is also play in the drum. More play downwards than up.
How can I gain access and change the bearings on this machine ?
What tools will be required and also the parts ie. bearing and seal etc....
Any help would be much appreciated.
I posted the question originally. Are you sure the back panel of the machine doesn't have to come off ??
How about the front ? What tools will be required
Posted on Jan 03, 2008
    Genius:
  • 1,665 Answers
There is an answer at this link:
http://www.howtomendit.com/answers.php?id=16357
"some you can get at and some you have to lift over the top, when you get there you will need to smack the bearings out, maybe a old socket set with a long tube just to fit inside the bearing hole?. for what its worth go to the tip you might find one, that just wants a door seal?"
You must have some technical experience.
good luck!
Posted on Jan 02, 2008
Replacing drum bearing on a ZANUSSI FJS 874 front loader ?
This is not a simple job, it can be fine but requires the complete disassembly of the machine to change the bearings, there are 2 bearings and a seal that require replacement, I can assist in guiding if you wish to do so, it takes around 3 hours total to strip and rebuild.
Jun 16, 2016 | Zanussi Washing Machines
Hi I have a zanussi Jet system FJS 1397W washing machine, the problem with it is that, the drum does not spin round any more- What is likely cause? thanks
hi check the pump first it has to drain before it spins the other cause could be the module control board the control the motor speed hope it helps
regards
shaun
May 27, 2011 | Zanussi FJS1225W Front Load Washer
My 10 year old Zanussi front loading w/machine makes a lot of noise sometimes when spinning. Can this be fixed or is it time for a new machine?
Time for a new machine. Bearings are gone. It can be fixed but will be costly as it will need a new drum rear.
Feb 22, 2011 | Zanussi FJS1225W Front Load Washer
My zanussi essential 1200 6kg makes a really loud knocking noise when it spins. How do i repair it please?
Firstly,put your hand on the silver drum and revolve it back wards and forwards(side to side) ,if it feels as though it is or sounds rumbly the bearings have gone-not unknown with this make at 3 years of age!If this seems all ok,put one paddle in front of you and try to press down the drum at the front lip to see if it moves in relation to the front of the plastic tank-your trying to prove that the bearing shaft spider assembly hasn`t cracked-3 arms which are bolted between the drum and tank that holds the drum in place ie the bearing shaft-these arms match up to the 3 paddles.The spider is made from an AL2 alloy which is attacked by a fungus and makes it brittles so it cracks!!-strange to believe ,but true!!!!Suggest you turn of the power to the machine,undo the two lid screws at the rear of the machine and remove the w/top lid.Have a look at where the rear half and front half of the plastic tank are joined-i think from memory that these two are factory heat wielded so that it is impossible to dismantle the tank to replace the bearing or assoc parts even if you wanted to due to cost.Have alook and see!best of luck
Dec 02, 2010 | Zanussi IZ161S Front Load Washer
Location of bearings on a zanussi fla100w
how do you change bearings on zanussi fla 1101W
Jan 11, 2010 | Zanussi FLA1101W Front Load Washer
Zanussi FJS 1425W - the machine is not spinning the clothes so clothes are quite wet when they are washed so have to spin but this is also not working well - washing purchased approx 7 yrs ago -
hotpoint top loading washing machine serial number TS182924N MODEL NUMBER HNXR1060T8WW. machine won't spin and will not empty water, just a humming noise. number on scamatic diagram 175D275OGO71 MACHINE IS APROX 20 YEARS OLD
Jan 06, 2010 | Zanussi Washing Machines
Burning smell and loose drum
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi FJS1225W Front Load Washer Logo
210 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
