Donna, If yours is a frost free unit, it may be going through a defrost cycle, which it should complete on its own, and then the compressor will start and resume cooling. Otherwise, if the compressor was under too much pressure to re-start, just leave the unit unplugged for 20 minutes or so while the pressure dissipates, then try again.
We have had several problems with our MSD2756GES side-by-side frig (mostly related to the ice...
(More)
We have had several problems with our MSD2756GES side-by-side frig (mostly related to the ice maker). In the last couple of years we have replace the #61005626 Water Valve and the #61005988 Adaptive Defrost Encl and have had to clean/defrost the drain hole several times. Now the ice maker is dripping water on the wall and shelf below it.
the external water and ice cube dispenser still dispense after pulling away. is this a stuck switch...
(More)
the external water and ice cube dispenser still dispense after pulling away. is this a stuck switch and is it easy to repair
first the climate zone drawers started getting too cold and freezing everything,I turned the drawers...
(More)
first the climate zone drawers started getting too cold and freezing everything,I turned the drawers off but now the entire fridge is too cold, even my eggs are frozen. And turning the thermostat to warmer is not working. Everything is still freezing.
