Question about Guido Bergna Mia Coffee Maker
Steam leak in GB Mia Espresso Coffee maker
No matter how much I tighten the top to the bottom there continues to be a steam leak. The espresso maker is new, the gasket is good. Any suggestions?
  • Pierre41 May 17, 2008
    I just purchased a Guido Bergna Mia coffee maker and it leaks steam no matter how tight I turn the top part. The unit is new out of the box.
I had the same trouble before and probable causes were:
too much coffee powder in the funnel?
or
the coffee beans are ground
too much, makes the power clogging in the bottom of the steam tube?
Posted on Dec 29, 2008
No water coming out
Espresso Makers FAQs at MrCoffee.com.
www.mrcoffee.com/.../espresso-makers/espresso-makers-faqs....
Mr. CoffeeBrowse our Espresso Makers FAQs to find answers to common questions about Mr.Coffee products. ... Why isn't espresso coming out when I try to brew a cup?
Steam Espresso & Cappuccino Maker (ECM160-NP) - Mr ...
www.mrcoffee.com/.../mr.-coffee...espresso...maker...-/ECM1...
Mr. Coffee
Rating: 2.7 - ‎32 reviews
coffee-steam-espresso-and-cappuccino-maker--ecm160-np-/ECM160-NP.html ..... Thecoffee grounds don't come out wet like the other unit. ..... too much as the steam pressure only (no pump) isn't enough to force the water through the "cake".
Repair Your Clogged Coffee Maker - Instructables
Dec 21, 2015 | Mr. Coffee Coffee Makers & Espresso...
Steam Wand Leaking on La Pavoni Espresso Si
I HAD the same problem. I fixed it for 50 cents. It takes the removal of 4 screws (2 phillips on top, 2 long standard on bottom by the group) to remove the top to access the steam wand valve. Once the the top (and the chrome bezel) is removed, then screw out the valve counterclockwise buy ALL THE WAY until it comes out. There are 2 O-rings on the stem of the valve that wear out, Cut these off with a sharp knife, go to your local hardware store, buy 2 new ones for 50 cents, install new O-rings, and reverse the disassembly procedure. Voila, no more leaky steam valve!
Jun 20, 2009 | La Pavoni Espresso Si PAB-16 Espresso...
Gaggia syncrony compact is leaking. Removed top and it appears it is leaking from the area that the line goes into the steam knob. Doesn't leak when using the steam knob, just when brew coffee
Hi What color is the steam manifold? It is located under the black cover with the trough in back under the whit tube. If its whit or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
Jun 14, 2009 | Gaggia Syncrony Compact Coffee...
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
Steam wand loose
you can tighten the steam want with a wrench. At the top of the wand just before it enters into the machine you see a "nut" use this to tighten or loosen the wand
Jan 05, 2009 | FrancisFrancis! X1 Espresso Machine
Guido Bergna Mia Coffee Maker Logo
734 people viewed this question
Top Guido Bergna Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Guido Bergna Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
