Question about Iomega 33089 250 GB Hard Drive
Cooling fan my cooling fan is making a loud whining sound. Can this fan be replaced?
  • jmh1965 Jan 02, 2008
    I should have mentioned this is an external hard drive. It is not part of my computer.
    Problem Solver:
  • 11 Answers
Yes. It can be replaced. Try to check which fan is making that sound. Do you have a laptop or a PC? On a PC, there are 3 standard fans inside it. one for the CPU, one for the power supply and one for the computer casing fan as well. It depends on which of those fans it's coming from. On a laptop, some laptops' fans actually makes a loud noise which is common but there is a way that it could be lessened but it might slow down your pc and it might overheat it as well. The loud noise on the fans of a laptop actually indicates that it's trying to cool down the system. If it doesn't stop the loud noise, it could indicate a problem switching the fans back to normal and would just continue to spin fast. Try to contact your PC tech for further diagnostics on the laptops fan to indicate if the problem is with the fan or the mainboard as well.
Posted on Jan 02, 2008
Noisey sounds from under the hood when starting car
If it is a rattling sound the starter may be loose, the starter bendix gear might be damaged.
If it sounds like a fan, it is likely the cooling fan.
If it is squealing, it is the serpentine belt. The idlers may be worn, their bearings may be dry- they make a chirping sound at slower speeds when they are dried out. Replacement is the best option.
Air pumps can sometimes make a thumping sound, and if certain emissions valving rusts through, it can be outright exhaust noise.
If it is a high pitch whine, that is usually the alternator. It is not a good sign when they begin to whine. Alternator bearings can also fail, and the sound varies.
Water pumps and fan clutches can also fail and they tend to make softer sounds. These can be checked by checking for radial play in each item with and without serpentine belt tension applied.
Jan 18, 2012 | Cars & Trucks
We have a constant buzzing/whining noise when the TV is on.
Is it a whuring or buzzing sound? When color wheels go bad they can make a lot of mechanical nose, cooling fans can do the same but they do not spin as fast as a color wheel does
Jul 08, 2010 | Samsung HCM4215W 42" Rear Projection...
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
WHINING SOUND
More likely it is the color wheel this set uses---it is located inside the optical engine---part number for it:
267888This part is no longer available from RCA but is available on several sites on the internet (google the part number)
The wheel will when going bad sometimes make a fan like noise or even a high pitched whine.
Check out the sites on the net that sell this for price and decide if you want to attempt to replace it or if you have to have a shop do it for you.
Let me know if you have any questions or need advice.
REGARDS, SD TECH
Oct 05, 2009 | Televison & Video
Loud whining noise
had 2004 tb has a chip on the cooling fan its self your fan may be going out does sond like a turbin or a jet lol if so its the fan sensor
Sep 29, 2009 | 2006 Chevrolet Trailblazer
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
When our refrigerator kicks on, after a minute or two it makes this loud whining, from soft to loud, that lasts about 2 to 3 seconds and does it continually till it kicks off. It's like, Waaaaah, waaaaah,...
This sounds like a compressor that is whining. Or something maybe wrong with the fan motor. You can stop the fan to see if its still there. If it is then its the compressor making the noise.
Sep 13, 2009 | Haier Refrigerators
Loud accelerating whining
It is the bearing in the idler pully. about $35 and 30 minutes of work and its fixed.
May 20, 2009 | 2006 Chevrolet Trailblazer
I have an RCA model #HD50LPW62AYX2 hdtv/dlp rear-projection set. The picture went out, and we thought it might be the bulb, so replaced it. The picture still will not come on, and there is a loud...
The color wheel can make a whinning sound for sure, However it should not continue to whine after shutting it off. That sounds more like the fan used to cool the lamp, as that will continue to run after the set is shut off. How soon does the whinning start when you push power? Let me know I should be able to help you out. DLPs are my specialty
Mar 26, 2008 | Televison & Video
Infocus x1 projector
Indeed, the problem you describe is the Color Wheel. Very common issue in the X1,2 projectors. Unfortunately the only fix is to replace this wheel. The cost of the part generally runs around $175 but the labor to replace is about the same. You will need to find an authorized service center where you live or send it to a repair facility. Parts for any of the InFocus units are generally not available to the public, alas the Service Centers. Maybe for the same cost you could look at a new projector, like I did.
Jan 18, 2008 | InFocus X1A DLP Slide Projector
Iomega 33089 250 GB Hard Drive Logo
662 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Marvin
Marvin
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
