Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have
a problem that requires professional repair.
Was this helpful?
Yes
No
Popular Solutions for Kodak EasyShare Z740 Digital
my kodak easyshare Z740 that i have 4 2 years starting chewing up on batteries really fast. I was...
(More)
my kodak easyshare Z740 that i have 4 2 years starting chewing up on batteries really fast. I was using rechargable batteries and thought they expired so tried using duracell but same problem occurs and camera turns off without a warning
my camera won't turn off and when i open it , it says no "No images in Favorites and it will...
(More)
my camera won't turn off and when i open it , it says no "No images in Favorites and it will not take picture. The should be green but it's orange
