Question about Olympus Stylus 700 / 700 Digital Camera
Dark spot in centre of screen.
Today I have a dark spot in the centre of my screen. It only started today. it is quite intensely black in the centre but has fuzzy edges. What is it and what can I do to stop it?
I have a little dark spot that i noticed it today too on my canon SD870IS i hope somebody can tell us what's the problem
Posted on Feb 05, 2008
My cayenne s
This could actually be a fault in the quite a few different modules.
It could be the centre console buttons, or even the main module.
Unfortunately you need to get VAG-COM or VCDS to see the error codes.
I used a Ross-Tech cable and determined the issue was a failed module.
Any VW, Audi or Porsche service place can connect in and see what the car is reporting.
But this may be best to let Porsche run diagnostics.
Also if it is a module, dealerships tend to have to replace them.
As second hand modules have a CP protection lock on them.
May 12, 2014 | 2008 Porsche Cayenne
Hi.i m central excise and service tax inspector.i purchased nikkon coolpix s3000 on 04.05.2010 from chennai. today i chkd n found one black spot on the screen some whitish linings like on the screen...
why are you so worried, if it is a genuine nikon purchase it is still under warrant, problem becomes sever if you have dropped the camera or some water has entered the unit.
i beleive chennai has a nikon authorised service centre.
Dec 22, 2010 | Nikon Coolpix S3000 Digital Camera
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
I just replaced all 8 bulbs in my projectors. we are a large church and they are used quite a bit each week. when i tested them yesterday, one of my projectors had a yellow dull spot in the center of my...
Hi
If spot is light ( like a clouds ) then probelm is with dust .if is dark then LCD panel is faulty.pl conatc your nearest service centre
ANS BY
M.R. Mumbai & Dubai
Aug 31, 2010 | Sanyo PLC XF45 Multimedia Projector
Hi. I own a Sony KP-51WS500 rear projection system where several months ago the red arced lines started to appear accross the entire screen, dim at first but growing in intensity. In the last few days the...
This is a model prone to all three tubes failing in this way. When the sets were less than a year old there was a program from Sony to replace all three tubes--it seems the wrong tubes were installed.
The tubes are now only available on a rebuild basis--take out old one and send out for rebuild and very expensive.
An alternative exists, it involves (in your case red) getting at the RED SCREEN CONTROL AND TURNING IT DOWN UNTIL THE SET DOES NOT SHUT DOWN and then adjusting it further. No parts will be involved and should take less than 20 minutes.
Set will shut down if screen turns bright red, green or blue as it detects too much current is being drawn.
If you want to know how to attempt this, rate this solution as very helpful and I will assist you.
SD TECH
Aug 31, 2010 | Sony KP-51WS500 51" Rear Projection...
I have a sony projection tv. The screen is very
Mine was what I considered to be dark for quite a while--even after setting the brightness as high as it would go. Today the lamp went out. It just has to be replaced.
Apr 09, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
All of a sudden today my phone rang, I answered it, then the screen went blank...at times it shows a split gray/dark gray screen.
Switch off and on your phone, if screen is in same mode , then there will be problem with your display....Take to service centre.... and service it...it will work...
Let me know feedback..
Thank you...
Oct 02, 2009 | Sanyo Katana Eclipse X Cell Phone
Same thing happened to mine today
i don't know the service centre till now
Aug 23, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Olympus Stylus 700 / 700 Digital Camera Logo
490 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
