Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Wireless connection works and then disconnects itself
I have been using the router wirelessly for several months without an issue. Recently i am having issues staying connected. It seems like I can connect fine and then in a few seconds a red X is displayed over the wireless icon. Also, when I refresh network list sometimes my network is there and sometimes it isn't. If I connect the cable from the router into my laptop i cannot get on the internet.
This used to work fine, nothing was changed. How can I troubleshoot?
  • belkinuser1 Jan 03, 2008
    I ran the Net Stumbler. I did change the channel because most of the channels were the same as mine. I did eventually get on the wireless network but it does seem to connect, disconnect, connect, disconnect many times before it stabilizes.
    Any other things I can check? Its not just my laptop, there is a second laptop in the house that seems to be having the same issue.
  • cool_katz Feb 28, 2009
    I have the same problem. My wireless connection was not stable. After connected to internet then in a few minutes my connection will be disable (wireless network not found) and then auto-connect again and then disable again it like a endless loop. It's quite frustrating. Is this a sign that I need to replace my belkin router? or there is still a chance to fix this problem?
    Problem Solver:
  • 13 Answers
Look for a program on the web called Net Stumbler
It should be here http://www.stumbler.net/
That will show the signal level from your router.
I have seen this before and it could be several different problems
1. Someone else on your channel
2. Burned out ant or output section in the router
3. Broken Ant wire in laptop
Hope this helps
Posted on Jan 02, 2008
  • DHeinrich Jan 03, 2008
    Using Netstumbler, you can see the amount of signal that your router is generating. But with the second Laptop having the same issue, it points to the router being the problem. Beyond the standard stuff like checking that everything is plugged in tight, you will probably have to open the unit and physically check if there is damage to the circuit board. I have a box full of half dead routers (work as router but wireless burned out) that have had power spikes that were caused by the wall transformer. They spike and cause this type of problem. It now just not worth repairing because a replacement units can be bought for under $50.00.
    Sorry, I can help more.
    BTW If you have to replace the unit, go to the Liknsys units.
    They have the best overall usability and reliability IMHO.
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 01, 2013 | Computers & Internet
Bought router in 2009 and worked fine up until about a month ago. Every couple of minutes will disconnect. Wireless connect on laptop shows it is connected. I get page not found. Soon as I unplug it...
try updating the firmware to the latest version.
http://en-us-support.belkin.com/app/answers/detail/a_id/306/~/f5d8236-4-n-wireless-router---firmware
it may fix any bugs or wireless issues in the update.
Apr 05, 2011 | Belkin F5D8236-4 Router
At&t wireless router and magic jack setup
It could be the router which is giving you issue. Press and hold the reset button for 30 second and this makes the configuration to go back to its previous settings. The reconfigure the router with a new SSID and security key. Try connecting to the wireless network, the computers will consider it as a new network and will connect without any issues
Apr 09, 2010 | 2wire 1800HG Router (RG1800HG00)
My wireless connection connects then disconnects
I would check two things on the router
  1. remove the wireless encryption and see if that makes any difference
  2. look at the channel being used - if you have a PC available that is connected by wireless to the router - you can use this program to check what channels are being used http://www.xirrus.com/library/wifitools.php and then change the channel to one that is not being used - ideally use channel 1 or 6 or 11
  3. Does the phone work on any other wireless signal without loss - if not then it may be a dns issue and we need to set up public dns ips for the phone - post back if this is the case
Mar 24, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless not conecting to internet.
Long time back I had a similar issue. It could be a virus in ur system that is blocking ur internet. If you have recently downloaded any files especially WINRar, then it might have the trojan that kill ur internet. Run your virus scanner completely, if it does not show anything, try Malwarebytes Anti-malware, download it from download.com and not from anywhere else. HTH.
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
Zoom aDSL modem/wireless router seen but not connecting
Here are a couple of ideas to look at first, assuming you haven't tried them already:
1) Does moving the router help? Sometimes a new DECT phone or a microwave, or even a piece of equipment at a neighbour's house, can interfere with the signal.
2) Does changing the channel on your router help at all? If there are many other networks using the same channel, this might block your own signal.
3) If this does not make any difference, it might be worth checking your security settings.
Nov 14, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
New Laptop Connection
Are you connecting and configuring using wireless or cable?
Sep 07, 2008 | Linksys Wireless-G Broadband Router
Use of router in network
Try reset the router & cable modem. There ia a reset (very small) button on the back of the wireless router & the modem. Disconnect the power cords to both. Use a pen & hold in for 10 seconds (router & modem). Re-connect power (router & modem) & restart PC. If your service still has not returned. Chances are it's your internet provider & not you. Double check by connecting your modem directly to your PC.
Luck!
Mike
Apr 04, 2008 | Linksys Wireless-G Broadband Router
Several Router problems
It sounds like an ADSL signal strength issue. Test that it is not a problem with the ADSL phone cable setup, using the shortest ADSL/Phone cable you can find (under 1Meter is best)unplug all other phone line using devices and filters from the wall jack points and test the routers connection again as the only device plugged in(this is Isolation testing) If the issue replicates itself under isolation testing conditions then ring your ISP providor and request that the "ADSL signal voltage" needs to be increased slightly as your router is not hearing the ADSL signal properly. If the issue doesn't replicate itself under isolation test conditions, you are either using an old or bad ADSL/Phone cable or your cable is too long (should not be longer than 5meters)or if you are using a wall socket/splitter for direct adsl access (without filters)then test the socket with a filter to verify the socket/splitter is not the cause of the problem, if you do use phone filters, during isolation testing, test each of the filters individualy with the router and see if the disconnection issue is replicated if so replace the bad filter the disconnection issue was being caused by phone signal interferance. Your third request requires you to setup the LAN info on the windows side of your connection not the wireless card, this can be verified by searching for websites via thier IP address which will work, when searching via their website name wont, DNS resolution issue, it is probably best practice to use MAC Addressing for your wireless setup though.
May 15, 2007 | Trendware TEW-452BRP Wireless Router...
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
618 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
