Question about KitchenAid KSRB22FNSS Stainless Steel
Water dispensor not working
Kirtchen AID isde by side 22ft. with water/ice dispensor
My water dispensor is not working. Ice dispensor is fine.
What is the most common problem?
    Problem Solver:
  • 10 Answers
Since you have water getting to the icemaker/dispenser, the most common problem I've seen is the solenoid valve is history and needs replacing. It could also be the switch that is normally activated by the dispenser itself and in turn activates the solenoid valve or the wiring in-between the switch and valve, but I have personally not seen either one of those go bad.
Posted on Jan 02, 2008
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Doors got to hot
Check the warrenty on fridge . Usually you have a 5 year warrenty on the compressor AND sealed system ( parts and labor ) . However , a service call charge may apply . Also check to see if something got sucked into the compressor cooling fan blade causing the noise , after you cleaned the coils .
From the description about dispensor leaking and ice getting stuck , sounds like the water valve needs to be replaced . Small ice cubes ( from not enough water ) will get caught between the rake and fingers . A leaking water dispensor , usually indicates that the water solenoid is not closing completely when letting off the water dispensor arm . Both solenoids come togather as the water valve ( located where the wall waterline connects to refrig ) .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker works, fills door but doesn't come out
You have a bad dispensor flap solenoid . Frost due to flap not closing completely and ice will catch in the shoot .
Jul 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
The ice dispensor is frosting over. Ice maker
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Water dispensor does not dispense water. Ice maker works.
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
May 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
Water dispensor is not working, ice dispensor is work fine
It depends on where it is freezing. Can you determine where the freezing is? These things don't usually clog. They can develop what is called a vapor lock in the water dispenser behind the meat drawer in the refer. For freezing let me know where it is freezing.
Nov 18, 2007 | Hotpoint HSS25GFP Side by Side...
KitchenAid KSRB22FNSS Stainless Steel Logo
145 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
