Question about Asko W6021 Front Load Washer
Fault 02 washing machine stopped mid cycleand displayedfault 02 and stopped and will no longer run,can anyone help ?
  • 3 more comments
  • athena2 Jan 02, 2008
    The display panel also read malfunction
    temperature failed, besides the fault 02
    display. Now the washer has power but
    it will not turn on.
    No. It is older than that. We bought the
    house with the washer and dryer in it. I think it is about 7 years old.
    there is no program contol knob that says drain. It also apppears there is no
    water in the machine. On the front
    panel it says W660 Quattro, just to be
    sure we are talking about the same model.
    thanks, any other ideas??
    That's it. I am sorry about the incorrect
    model number. It is the W660.
    thanks
    NO. ONLY WITH THE EMERGENCY LATCH.
  • 319 Answers
Hi
Fault code 2 indicates "Water level too high "
Please look for the following causes:
· Plugged/Bad water pump
· Faulty water valve
If you are not able to check these, it may be necessary to call for a technician. Always be careful of electricity!
Posted on Jan 02, 2008
  • 4 more comments
  • Brian Berndt
    Brian Berndt Jan 02, 2008
    IF this item is less than 3 years old, it carries a FULL WARRANTY--Parts and Labor. Is that the case for you?
  • Brian Berndt
    Please also try to drain the machine. This may be able to happen by turning the Program Control Knob to DRAIN, then Press START, the water should drain shortly thereafter.
  • Brian Berndt
    Sorry, the post said ASKO W6021 Front Load Washer. I will continue...
  • Brian Berndt
    Please click this link to verify that this is what you have.
    http://www.askousa.com/pub/manuals/washe...
  • Brian Berndt
    Are you able to open the door?
  • Brian Berndt
    My next suggestion is to turn off the Power, wait then turn On the power. Then please open the door and be sure that the items are not unbalanced (probably not the problem, but just to be sure). Then please try to select a wash cycle different from the one that you were using. Try one with a low temp wash such as Handwash.
    I am afraid that your wash cycle may not advance because the water is not getting hot enough. This will probably require a service call, or maybe a late Christmas Present (a new washer) for you!
Whirlpool duette washer stops during cycle beeps and displays error code F
The f should be followed by a digit or two that indicate a particular fault code. A mid cycle stop with a fault code might be because of a long drain time due to a
Faulty drain pump or clogged drain filter but without the entire fault code it’s difficult to give an exact answer.
Feb 11, 2018 | Whirlpool Washing Machines
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Doesn't work. Why does it stop mid-cycle?
    washing machine stopped mid cycle, won't drain : DIY - Reddit
    https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
    RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
    Troubleshoot - washer stops mid cycle, won't drain or spin ...
    ? 1:58
    https://www.youtube.com/watch?v=6Gc0ZgLD6a4
    Jun 20, 2012 - Uploaded by searspartsdirect
    Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
    Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
    Why does my washer stop half way through cycle - Ken
    Dec 18, 2015 | Washing Machines
    Stops mid cycle and clears
    It could be the heating element is at fault not heating to the selected temperature 95 degrees 40, 30,and so on, if one of these fail to work then the washer will not continue
    also maybe the thermostat may be at fault, causing the same error
    Nov 18, 2013 | Zanussi ZWF1020 Front Load Washer
    My Fisher and Paykel IW810AU has stopped mid wash full of water and just beeps constantly and flashes message I need Service Fault 105. Have turned it on and off at the wall with no change. Please help.
    Hi, the faults 105 is reported when the Display Module detects an error in the communications between the Display Module and the Motor Control Module.
    The primary source of the problem is the Pump and you have to measure resistance of pump. If resistance is less than 33 ohms, replace pump.
    May 16, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
    My washing machine stalled and screen says F..02. Can anyone help???
    Don't know the model of your washing machine but, inside the machine's cabinet is a service manual that will give you a list of definitions of faults. Reply back to this post if the fault is something you are not familiar with.
    Nov 30, 2010 | Hotpoint Washing Machines
    E20 fault display
    E20 is a fault either in the filter/pump or drain.
    The water must be drained thru. the little hose by filter or get machine to back door and undo filter plug and drain onto back step its quicker.With filter out see if any blockages,shine torch up in filter hole turn to spin/drain and see if pump blade spins if not then get long screwdriver and turn blade to free if no joy pump has to come out to free,hopefully this will work and refit plug and check for leaks.Then try again.
    Good luck.
    Apr 19, 2010 | Zanussi ZWF1420W Front Load Washer
    Washer stops mid cycle and displays F 02 error code.
    it means that your pump is clogged you need to take that bottom panel off the washer and twist the white cap slowly so it can drain put plenty of towels down once it is done draining pull the cap and clean the trap behind it
    Dec 25, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing machine fault
    lg trom showing E and on display won't drain
    Mar 26, 2008 | Washing Machines
    F-02 fault code on indesit we16 washing machine
    According to info on a similar site to this, it means motor jammed/tacho faulty or detatched
    Mar 23, 2008 | Washing Machines
    Asko W6021 Front Load Washer Logo
    114 people viewed this question
    Top Asko Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Oloyede Monsuru
    Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
