I am setting up my Sony STR-DG820 receiver. I have HDMI hookup from my blu-ray to my receiver and from receiver to my Sony Bravia. This system works great. My problem is that I also have a Sat-box, DVD and Wii hooked up to my receiver but I don't get the video feed to the TV. What's wrong?
hi my names josh your feeds arent going to feed out through that hdmi if your have hdmi coming in you will get that signal going out however depending on what your signal source is for the rest of your compenents that will determine your problem for instance if you if your runing all compenent which y p b or video which is just standard yellow red and white cables you have to stay with one or the other what you go into your reciever with you must go out with if analog wich is just video and audio you have to go out through your monitor out source to get a picure if compenent whic by the way will produce a far greater picture it is your y p and b jacks and the color of those are green blue and red those are just for picture only not audio you have to still run audio with these cables you go in the unit with those you have to go out with those directly to your tv then you want check you reciever video setting to make sure it is set for that and well as your tv to make sure you are in the right monitor or screen to get your picture
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Okay, thank you Josh. Your message is difficult to read. Short complete sentences would make your solution clearer but I believe I understand. Thx.
" - deryk_skeete
I have a Sony STR-DG820 when I turn the volume up past 30 the reciever goes into...
(More)
I have a Sony STR-DG820 when I turn the volume up past 30 the reciever goes into "protector" mode and shuts down. How do i fix this? help!
Sony STR-DG820, Sony 40-V Series LCD, Motorola DVR HD Cable Box (Comcast), Sony Blu-Ray BDP-S300 -...
(More)
Sony STR-DG820, Sony 40-V Series LCD, Motorola DVR HD Cable Box (Comcast), Sony Blu-Ray BDP-S300 - All connected via HDMI. Power TV, Motorola Box, and Amp unit - no sound. Switch receiver to tuner mode and then back to SAT mode (where cable box is input) and sound works? It just started doing this. Pic does work, just no sound until switched to another mode on the AMP. Any ideas?
no sound form the subwoofer even when i do the auto calibration. my sud does not have a seperate...
(More)
no sound form the subwoofer even when i do the auto calibration. my sud does not have a seperate power source, i just goes strait to the receiver. can anybody help?
Just hooked up all new equipment.... Cable receiver using hdmi; and blu ray using hdmi. STR-DG820...
(More)
Just hooked up all new equipment.... Cable receiver using hdmi; and blu ray using hdmi. STR-DG820 Samsung 1600 Blu Ray Motorola Cable box from Rogers (High Def) The system sounds great, but while listening to a music channel on cable, the sound was cutting in and out and then the amp just shut down. I used the autocalibrate after connecting everything, but I havent changed any other settting. I am using the Klipsh quintet III speaker system with a matching subwoofer. Should I attempt to change other setting on the amp?....I have no idea what to do.
