Diagnosis PS only works when "TEST"button is held
  • 107 Answers
Some power supplies have a microswitch that prevents a turn on while the case is open. Sometimes it's a switch on the case, or a switch linked to the mobo. You can try to defeat that. Also PSU's are made so they won't turn on unless hooked to a mobo. You will have to jump some pins to defeat that. This info is readily found in Google.
Posted on Jan 04, 2008
I have a 2012 f150. the climate control module quit working. all lights work. air only out floor. replaced module with used one, works the same. Ideas?
Taking the vehicle to ford an having the modual programmed . You can't just replace these modules . Give them the old one ,check for DTC'S - diagnostic trouble code's . Nothing you can or should do.
NOTE: Some PCM DTCs may inhibit A/C operation. If any PCM DTCs are retreived, diagnose those first. Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual. DTC Description Action to Take B1003 Mode Door Short/Failure Go To Pinpoint Test F . B1200 Stuck Button Button held too long may set DTC. ATTEMPT to clean buttons. If code returns, INSTALL a new electronic automatic temperature control (EATC) module. REFER to Section 412-01 . B1251 In-Vehicle Temperature Sensor Open Circuit Go To Pinpoint Test A . B1253 In-Vehicle Temperature Sensor Circuit Short to Ground Go To Pinpoint Test A . B1255 Ambient Temperature Sensor Open Circuit Go To Pinpoint Test B . B1257 Ambient Temperature Sensor Circuit Short to Ground Go To Pinpoint Test B . B1342 EATC Module Faulted INSTALL a new EATC module. REFER to Section 412-01 . B1676 Battery Voltage Out of Range Go To Pinpoint Test Q . B2266 LH Blend Door Failure or Short For vehicles not equipped with electric heater, Go To Pinpoint Test K .
For vehicles equipped with electric heater, Go To Pinpoint Test L . B2267 RH Blend Door Failure or Short For vehicles not equipped with electric heater, Go To Pinpoint Test K .
For vehicles equipped with electric heater, Go To Pinpoint Test L . B2268 Steering Wheel Control Switch Circuit Open Go To Pinpoint Test D . B2269 Steering Wheel Control Switch Circuit Short to Ground Go To Pinpoint Test D . B2426 RH A/C Solar Radiation Sensor Open Circuit Go To Pinpoint Test C . B2427 RH A/C Solar Radiation Sensor Circuit Short to Ground Go To Pinpoint Test C . B2795 LH A/C Solar Radiation Sensor Circuit Short to Ground Go To Pinpoint Test C . B2796 LH A/C Solar Radiation Sensor Open Circuit Go To Pinpoint Test C . U2050 No Application Present INSTALL a new EATC module. REFER to Section 412-01 . All Other DTCs - REFER to the Master DTC Chart in Section 419-10 .
Apr 27, 2018 | Cars & Trucks
I have a fellows ps 75 and it will not shred. If I put it in reverse it works, is there a reset button
most do not have a reset button
what it does have is a small plastic finger between the center cutters that presses on a small micro switch to turn it on as you push in the paper
it is a regular occurrence that uncut paper will accumulate at this point and jam it preventing it from starting or stopping
call a technician for a diagnosis
Nov 26, 2016 | Office Equipment & Supplies
How to turn off the service light after servicing?
1) hold the mode button for 5 seconds,then still holding it turn the ignition on,keep the mode button held for 15 seconds with the ignition on and the spanner will go away.
2) Go to menu. select 'Diagnosis' enter the code. 98789, scroll to 'Reset Coupon', hold button down. Choose 'Yes', Hold button down. Retreat out of menus. Job done.
Aug 14, 2015 | 2011 Aprilia Dorsoduro 750
What do i do when my fridgidair electric dryer displays error code e68
Good Afternoon Friend, this is Z. Thank you for your post!
If you are getting an error code E68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). Let's try entering a "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps!
May 22, 2014 | Electrolux Dryers
What causes LEQ70000eGO dryer to continue to be on but dryer does not run. code E68
Hello Tam, thank you for allowing me to assist you!
If you are getting an error code E68 on your Frigidaire dryer (LEQ7000EG0), it usually indicates that one of the keys (buttons) is stuck closed (active). Enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps! - Z
May 19, 2014 | Electrolux Dryers
Hard drive not found system wont do anything you have to unplug to shut it down held power button down after powering up it asks to push ps button and bring up menu but nothing works
has the console been opened or repaired before is so then the blueray was changed for a wrong one ,or it needs updating visit xbox360repairspro.webs.com
May 27, 2011 | Sony Playstation 3 (PS3) Console
2 synch lights on ALL music controllers after PSN v2.8 update
You have to manually sync the instruments. While playing press the PS button go to settings, accesory settings and assign each controller individually a number from 1-4.
Jul 04, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
Dualshock 3 sixaxis why does it always need to be plugged in
Once the controller is plugged in and connected to the console, hold down the PS button to select "turn off the system." Once the system has completed shutting down, unplug the controller and press the PS button. The console should turn on. If so, the controller will connect wirelessly. Unfortunately you'll have to do this with each controller but it works every time.
Feb 19, 2009 | Sony Dual Shock 3 Controller for...
PS3 guitar hero world tour not recognizing drums
GOT IT!!!!
beebe623 was right. with some extra steps. Simple steps here:
1. Unplug the drum receiver.
2. Turn off the PS3.
3. Remove batteries from the Drum Controller.
4. Plug in the Drum Receiver.
5. Put batteries back in drum revceiver.
6. Turn on PS3.
7. Hit the PS button on the Drums once. (all 4 lights should flash)
8. Push and hold down the button on the Drum Receiver for about 5 seconds, then release.
9. Push the PS button again on the Drum Controller. At this point the drums should be assigned a port and synced up.
All this is in the instructions that came with the game.
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
My PS-2 Slim always show " Please insert Plyastation or Playstation2 Format disc "
see if the cd is NTCS/UC,NTSC/J or PAL and see what is your ps2 designation see at the back you will see if it is NTSC/UC.
hope this helps.
Nov 14, 2007 | Sony PlayStation 2 Slimline Console
Computers & Internet Logo
129 people viewed this question
Alun Cox
David Payne
David Payne
