Mitsubishi WD-52825 52 in. Rear Projection HDTV Television
Problem for Mitsubishi WD-52825 52 in. Rear Projection HDTV Television
Mitsubishi wd-52825. red lamp indicator, new lamp installed
By wrafixx on Oct 30, 2009
mitsubishi wd-52825. I replace the lamp, and it still no picture, it is properly installed, door secured,I do hear the fan working, and the tv turns on with no image for a minute or so, then it turns itself off, and the red lamp light comes on. I saw that when I turn the TV on, the bulb does come on, just for 5 seconds, then it turns off.
please any help.
Best Solution
posted on Oct 31, 2009
Very Helpful)
Slinteriors
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 3688 votes
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" no wonder you are an expert, we are nothing without you. huge thanks " - wrafixx
Popular Solutions for Mitsubishi WD-52825 52 in.
Questions and Unsolved Problems for Mitsubishi WD-52825 52 in.
Do you recommend Mitsubishi WD-52825 52 in. Rear Projection HDTV Television?
Answer
Answer
I need a TV code that allows us to use our phillips remote with full function
Answer
Model WD52825: No sound when connected to ANT-1 which is local digital TV or to TV hard disc. . Had... (More)
Answer
My tv is off with a blinking light, when I turned it on, there was no image in the screen but there... (More)
Answer
Picture won't hold on screen. Jumps up and down and does not hold.
Answer
replaced the bulb with my old one and still have shaking line for picture. I wouldnt think the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WD-52825 52 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 756
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
