Question about JVC AV-48WP30 48" Rear Projection Television
E5 gone to s5
The channel e5 has gone to s5 and no longer works, this means i cannot use my nintendo wii =[
please help, sam
  • 4 Answers
Try re-setting your tv
Posted on Jan 02, 2008
6ya staff
SOURCE:
Error 209600 downloading internet channel on wii
Error 209600 occurs when your Wii times out while trying to connect to the Nintendo Wi-Fi servers. This could mean the Nintendo servers are experiencing high traffic, and that you should try again later, or that your bandwidth is too low. The Nintendo Wii does not work properly with anything lower than broadband connections, such as high speed cable or DSL.
Sep 29, 2011 | Nintendo Wii Console
Need help getting Netflix. My disc no longer works for streaming?
You no longer need a disc for Netflix streaming to the Wii. You can now go into the Wii Shop Channel and download a Netflix application that will allow you to stream the videos to your Wii.
A description/tutorial can be found here:
http://www.youtube.com/watch?v=eVMDcIeYE2Q
Jun 27, 2011 | Nintendo Wii Console
I'm trying to get netflix through my WII, and its telling me "not available in my region". what does that mean ?
Sorry to hear your having problems with your wii. It means that the region that you purchased your wii is not of USA or Canada. You can fix this from this information from Nintendo:
"Did you receive the message: "The Wii Shop Channel is not currently available in your region?"If you see this message when you try to access the Wii Shop Channel, then it appears your Wii console is set to the wrong region. To fix this:
  1. Select "Wii Options" in the lower-left corner of the Wii Menu.
  2. Select "Wii Settings" and click the right arrow twice to reach "Wii System Settings 3."
  3. Select "Country," and use the down arrow to scroll down the list, then select "United States" or "Canada."
  4. You will be informed that you will need to accept the User Agreements. To do this, select "User Agreements," click "Next," and "I Accept."
  5. Select "OK", and try accessing the Wii Shop Channel again."
This is from: http://www.nintendo.com/consumer/systems/wii/en_na/netflix/download_print.jsp
I hope this helps!
Apr 29, 2011 | Nintendo Wii Console
Error code: 051032 when i try to get on wii shop channel to download netflix
This error code means that the only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
Please follow the Nintendo Troubleshooting page for some steps that may resolve this for you: http://www.nintendo.com/consumer/systems/wii/en_na/errors/results.jsp?error_code=051032&system=Wii&locale=en_US&action2.x=33&action2.y=19
Mar 20, 2011 | Nintendo Wii Console
Wii system update displays an error code 32007
From WiiErrorCodes.com
To solve this error :
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds. Be sure to test both channels to see which works better or faster.
Set broadcast settings on your router to "Mixed." This usually produces the best results. If not, trying setting your router to "G" or "B" to test which works best.
The Wii could be unable to connect to Nintendo's servers.
Please wait and try again.
I hope this helps
Mar 05, 2011 | Nintendo Wii Console
Everytime i turn on my nintendo wii an error message occurs
This usually means the Wii was modified to play other region games and Nintendo has locked it out. In other words, the mod used no longer works and will need removed or replaced.
While holding down the reset button, turn on the power to the Wii. If a menu comes up then your Wii has been modified and won't work again until the mod is removed, assuming if it can be removed.
There is a decent blurb about it here, including instructions for users of Homebrew Channel and Loadmii. I neither use or endorse use of these modifications as it is against Nintendo's AUP/Service Agreement.
Mar 19, 2010 | Nintendo Wii Console
Wii Hack Gone Wrong...
Well i have 4.2u and installed it also. I didn't do bootmii either cause I heard bad things about it. Mine works fine. It could be something to do with your ios installs. I suggest to check that if possible.
Feb 02, 2010 | Nintendo Wii Console
Nintendo wii wont work with older model of Sanyo TV
how are you connecting the wii to the tv...through the rca jacks?  If so, you can not get to the input channels by the channel button.  On the remote there will be a button called either AV, Input, AV Video, Video, A/V, Input or something similar.  Hit this button until your tv goes to the appropriate av channel.
Mar 07, 2009 | Nintendo Wii Console
ERR!!!
i went to the support.nintendo.com and it helped me out lots by telling me what to do !!! i suggest it to anyone with a problem with their wii or any nintendo device !!!
thanks for asking !!!
cowy-moo608
Nov 09, 2008 | Nintendo Wii Console
JVC AV-48WP30 48" Rear Projection Television Logo
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
