Question about Panasonic DMR-ES20EG DVD Recorder
Will not turn on or reset
Our dvd recorder would not turn off after watching a dvd and then went through a recovery process. It does that for days and then when we forced it off as the manual said and then tried to eject the disk both with the normal open button and with the manuals overide optiion, this did not work. We tried re-setting it by unplugging it for as the manual said and now it just gets the time and will not turn on eject or anything else.
First try pressing and holding the stop and channel up buttons (at the same time) on the unit (not the remote) for about five seconds.
If that doesn't work, try pressing and holding the stop and power buttons at the same time.
Posted on Jan 25, 2008
What is my dvd/hard disk recorder doing?
The problem is probably data corruption.
Disconnect the unit from the power supply for 15 minutes...which will clear the memory buffers and reset the micro at reconnection.
Hopefully after that it will be ok. The first update of the day occurs around 5 am therefore you can switch off anytime up to say 0200 am and then power on when you like but at say 0700 to 0800 am.
May 24, 2014 | Sony Televison & Video
Pansonic DMR-EH55 DVD Recorder,
You need to reinstall software on your dvd
Apr 01, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
No power; no lights will come on. I was watching a recorded DVD and then all of the sudden it turned off and will not come back on.
The reason the DVD went off was because it was exposed to a high current and the power pack got burnt during the process.
To fix this, you have to get the appropriate screw driver, open up the cover of the player,
You will see the power pack, if it is covered, open it up and if it is not just go ahead and test the capacitors with a meter reader.
You will discover some burnt capacitors.
Disconnect the power pack, get another power pack and replace the old one, and the player will be okay once again.
Take care
Jun 14, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Since it went into "disk recovery mode" it now will not play dvds
Got the same problem. Happened 2 months after guarantee expired. **** machine. The only good thing is the harddrive and that is made by HITACHI not Panasonic! I go Sony next time. Panasonic quoted £200 plus to fix the problem. I only paid £220 when I bought it new.
Sep 13, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
RCA model DRC8335 Loosing the date and time
That will be a problem from the text side of the broadcast, the clock is set from the text transmission, ( in other words a problem from the transmitter ) possibly due to digital switchover or work on the transmitters. One possible solution would be to turn off auto clock setting, and/or auto summer time adjustment.
May 16, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Panasonic dvd/vcr DMR-EZ47V model.Code OOOOOO keeps going across.
You must manually hold in the on/off button on the machine itself (NOT on the remote) for approximately 30 seconds. This will shut the unit off. Then you can restart it.
Jan 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
IBM ThinkPad X41
Afternoon,
I hope this helps?
To recover the hard disk to it's original contents, do the following:
Note:
1. If the optical drive is not attached to your ThinkPad computer during recovery, DVD software and CD-recording software will not be installed. To ensure that they will be installed correctly, attach your ThinkPad computer to the X4 Dock and install the optical drive in the Ultrabay Slim before performing a recovery ioperation.
2. The recovery process might take up to 2 hours.
Attention: All of the files on the primary hard disk partition (usually drive C) will be lost in the recovry process. However, before any data is overwritten you will be give the opportunity to save one or more files to other media.
Power the computer using the AC adapter and ensure a fully charged battery is installed before proceeding.
1. If possible, save all your files and shutdown your operating system.
2. Turn off the computer for at least 5 secounds.
3. Turn on your computer. Watch the display carefully. While the message. "To inturrupt normal startup, press the blue Access IBM button" is displayed at the lower left of the screen, press the Access IBM button. The Rescue and Recovery workspace opens.
4. Click Restore your system.
5. Click Restore my hard drive to the original factory state and then click Next.
6. Follow the instructions on the screen.
7. When the recovery process finishes, press the Enter key. Your computer will restart with the pre-installed operating system, drive, and software.
Dec 02, 2008 | IBM ThinkPad X41 Tablet PC
Siemens computer
hi dear
i think it's processing stop causing by internal failure, it's about your speed of dvd recording ...try to used a slower speed
and try to refresh your burning softwre
ok
Mar 26, 2008 | Computers & Internet
Random codes keep poping up when it does work!
Like a vcr, t.v. signal-IN connected through the 'antenna'input, the t.v. signal should pass through the dvd recorder and u should see it even if dvd machine is off. How is dvd, Tivo, t.v. connected? Signal connected to [video input1],[s-video input]BEFORE OR AFTER tivo ? I assume that the t.v. is the last in line??!! I am sorry, my book does not have code explaned
Mar 19, 2007 | iLO DVD Recorder DVDR05
Panasonic DMR-ES20EG DVD Recorder Logo
531 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
