Our ceiling fan make a loud noise and the light does not come on seperatley from the fan, so now it is getting colder and I would like to see the fan off and the light on.
There should be a separate pull tab for the fan. sometimes, this gets hidden in the light fixture. If you take off the lamp covering, you should see some kind of tab that you can pull for the fan.
If this is not the case, then you can use a trick that I tried one time (it worked for me). There should be a switch on the fan that is intended to make the fan switch directions. If you put that switch in between the two directions (up position and down position, but you want to keep it in the middle), you will disconnect the fan from the light for the winter. In the summer again, just give that switch a flick in either direction and you will be golden.
I hope this was helpful!
Was this helpful?
Yes
No
Popular Solutions for Encon Industries 72009 SWIRL
how do i wire up a hvk 150a1 fan.i have two black wires coming from the fan but three wires on the...
(More)
how do i wire up a hvk 150a1 fan.i have two black wires coming from the fan but three wires on the socket lead.which wires do i connect together please.many thanks
I have a remote control on the wall. My fan is coming on and the light is turning on spontaneously,...
(More)
I have a remote control on the wall. My fan is coming on and the light is turning on spontaneously, without the use of the remote.
This kitchen fan is on the same
power line as the bathroom exhaust
fan. While cleaning exhaust...
(More)
fan. While cleaning exhaust fan,
wires were shorted,kicking off
breaker...and also burning what I
believe to be a filter. It's a
small black component about 1.5
inches by .75 inch,three wires
(purple,yellow,and red)having written on it Watson AC250V
MAX T 70'C
E127244
I need a replacement of this component. None of the pictured
fans on the sight looks like it,
so am not sure of the model name.
Thank you for time.
a "fan" of yours.
