Question about Sony Playstation 3 (PS3) Console
Ps3 online why does my ps3 says dns (80710102)
  • 1 more comment
  • rafaelsalama Oct 26, 2008
    my ps3 says DNS error (80964568) please help
  • Scotty Lamy Nov 30, 2008
    dont no y my ps3 say DNS error 80710102 i need some help plzz
  • Anonymous Feb 16, 2009
    i have the same problem
  • 3 Answers
Try to connect with PPPoE on IP settings. Don't set any DNS servers.
Posted on Dec 21, 2008
It means you have an error with your online connection. you need to portforward gotto
Posted on May 25, 2008
    Problem Solver:
  • 9 Answers
It is the serial number of your ps3
nothing lethal
Posted on Jan 02, 2008
4 Suggested Answers
SOURCE: PS3 cant go online with Belkin N1 wireless router
I have exactly the same issue as some of you above. As soon as I start my PS3 I manage to log onto the network for anywhere between 2 seconds and 2 minutes before I get the dreaded 80710102 error and have to reboot the PS3 to reconnect. I wrote to Belkin tech support and got the following reply... I Haven't tried it yet so don't know if it really works but thought I'd post it up here in case it helps anyone else out...
Hi Antony,
Thank you for contacting Belkin Technical Support.
We understand that the router does not support PS3. We apologize for the inconvenience caused.
A) To isolate the problem, please follow the steps given below to update the firmware and configure the router:
We recommend that you update the firmware from a computer that is connected to the router with an ethernet cable.
Please download only the relevant firmware on the router from the link given below. The firmware file would be according to the router version:
and save it to the computer.
- To update the firmware, log on to the router`s web interface by typing in in the address bar of the browser. The computer should be
Note: If you have changed your Router’s IP address, use that IP address.
- By default, the password is blank. Click the "Submit" button.
- Click on "Firmware Upgrade" under the option "Utilities".
- Click on “Browse” and select the bin file that you have downloaded.
- Click on “update” and follow the wizard.
- After updating the firmware, restore the router to factory defaults by clicking on "Restore Factory Defaults" under "Utilities".
- Reconfigure the router.
Please follow the steps given below for configuring the router:
- Disconnect the computer from your Modem provided by your "Internet Service Provider" (ISP) if it is connected to the computer.
- Reset the router to "Factory Defaults". The reset button is found at the back of the router. The reset procedure is,
- Unplug the power cable and then plug it back again. Wait for 5 seconds.
- Locate the reset button (inside a hole) at the back of the router.
- Hold down the reset button till the power-light turns solid, and then release it.
- Connect the router to either the telephone line or the filter.
- Connect the computer to port number 1 of the router.
- Make sure the corresponding lights are lit. The telephone light should be ON and solid.
- Make sure your computer has a valid IP address by following the steps given below.
1. Click on “Start” -> “Run” -> and type “CMD” and click “OK”.
2. Type “ipconfig” in the black window and check the IP address.
3. It should be in the range of 192.168.2.x, where “x” ranges from 2 to 254.
- If it is not a valid IP Address, please assign a static IP address, "Subnet Mask", “Default Gateway" and "DNS Addresses" in the computer by referring to the link below.
- Please reset the Internet Explorer browser settings by following the steps below.
- Open Internet Explorer. Click on “Tools” -> “Internet Options”.
- Under the General tab, click on “Delete Files” under “Temporary
Internet Files” and select "Delete all Offline content" box.
- Click on “Clear History”.
- Under the Connections tab, select “Never Dial a Connection” and
click on “LAN settings”. Uncheck all the options and click on “OK”.
- Under the Advanced tab, click on “Restore Defaults”.
- Click on “Apply” and then “OK”.
- Log on to router setup page by typing “” in the address bar of the browser. By default the password is blank.
- On the left under “Internet WAN”, click on the option "Connection Type".
- Select “PPPOA”, (If it is ADSL)/ PPPOE (If it is DSL) and click on “next”.
- Type in the user-name and password and then re-type the password given to you by your ISP. Make sure you type in the full user-name.
For Example, the format for the User-name should be " or .net"
- Also confirm the settings of “VPI/VCI”, “Encapsulation” values from your Internet Service Provider (ISP) and configure the same.
- Change the “MTU” to “1400”.
- Click on “Apply Changes” button at the bottom. Wait till it saves the data.
- Click on Home on the right top corner and then click on the "Connect" button. You should be able to go online.
B) Configuration of PS3:
Please contact Sony and assign static IP address and DNS on the PS3. The static IP address should be assigned in the range of the router. For example: The IP address you assign should not be used by any other device on the network. Please confirm the ports to be opened for the PS3 from Sony.
1) Please follow the instructions given below to forward the port numbers for PS3 on the router:
- Please open the Internet Explorer and in the address bar type in "" and "Enter". The computer should be connected to the router with an ethernet cable.
- Leave the password blank and click on "submit".
- Click on "Virtual server" under the "Firewall".
- Enter the port number under "Inbound port" & "Private port".
- Enter the Static IP address of the PS3 under the "Private IP address".
- Check the "Enable" box and click on "Apply changes".
2) Please follow the instructions given below to enable UpnP on the router:
- Log on to the router web interface at
- Click on System setting under "Utilities".
- Against the heading "UPNP Enabling", choose "Enable".
- Click on "Apply changes".
Note: The NAT feature on the router is enabled by default.
If the problem persists, please get back to us with the following information:
1. Type of connection provided by your ISP (Is it PPPOE, Dynamic or Static).
2. Name of the Internet service provider (ISP).
3. Version number of the router. You would find the version number on the bottom of the device. It would be a number in a series of thousands with a prefix “ver.”. Please confirm if the router is F5D8635?
4. Using the router, if the connection is stable on all the wired and wireless computers?
5. If the PS3 works fine with other networks?
6. When does the error come up? If it comes up for both, CAT5 and CAT6 cables?
Posted on May 28, 2009
  • 4 Answers
SOURCE: PS3 cant go online with Belkin N150 (I think) wireless router
You need to disable the UPnP function on the Belkin router. Log into the router(, and look under System Settings for the UPnP function and disable it. If you haven't changed the password on the router, the default password is blank, i.e., no password.
Posted on Jun 14, 2009
  • 42 Answers
SOURCE: ps3 DNS error 80710104
not a big problem check out this link here
Posted on Mar 29, 2010
How do i solve the DNS error 80710102
It seems like the DNS error is generally caused by problems on your ISP's end of the network, but that doesn't mean you can't have a crack at fixing it yourself.
Under your network connection settings try changing the DNS servers to the following numbers (they're free by the way)
Primary DNS
Secondary DNS
Also, try disabling media server connection as well. These simple steps should, in 90% of cases, fix the problem.
I've written a more in-depth guide to the causes of, and solutions to the DNS error- check it out here
Read more: What is a dns error (80710102) ' Answerbag
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
I keep geting a dns error code 80710102 on my ps3 what is this
Hi Sir
80710102 PS3 Cannot connect to the router with current IP information - Try rebooting your router
May 19, 2010 | Sony Playstation 3 (PS3) Console
Ps3 DNS error 80710104
Mar 29, 2010 | Sony PlayStation® 3 (80GB) Console
PS3 DNS error (80710102)
see i hav the same prob try putting this in
primary dns
secondary dns
ip address
if that dont work people say u should unplug your router 4 a couple of minutes then plug it back in
Aug 22, 2009 | Sony Playstation 3 (PS3) Console
Dns problem
put this # at DNS and hope that helps
Jun 04, 2009 | Sony Playstation 3 (PS3) Console
Dns server error
in the dns server # type in and that should fix the error
May 31, 2009 | Sony Playstation 3 (PS3) Console
Dns server error
is it an older game?
if it is then its because the website group hosting that game has stopped because not enough people play to keep the dns system up
May 28, 2009 | Sony Playstation 3 (PS3) Console
Won't sign on frequently showing DVS error (80710102) and input this code at the dns #. that should help
May 27, 2009 | Sony Playstation 3 (PS3) Console
Dns error 80710102
try mving your ps3 around into verous places around the room and try to find an internet connecion. you can go to settings, network settings, then settings and connection status list and it will show you how much internet you have.
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Ps3 internet connection
here is the code to enter at DNS and
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
433 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
