Samsung DLP HL-P5663W 56" TV
Problem for Samsung DLP HL-P5663W 56" TV
How do i remove the lamp to replace it?
By johneden60 on Oct 30, 2009
how do i remove the lamp to replace it?
Solution #1
posted on Oct 30, 2009
Not Rated)
dickdavis510
Rank: Guru  Samsung Televisions & Videos  Expert
Rating: 93%, 61 votes
remove small plastic cover located at lower right corner on the rear of the machine (1 screw).remove cover. lamp is held in place with 1 screw. remove screw and pull lamp out by its' handle. install new lamp (do not touch any reflective parts on new lamp) and re-assemble in reverse order.
Was this helpful?
Yes
No
Popular Solutions for Samsung DLP HL-P5663W 56" TV
Questions and Unsolved Problems for Samsung DLP HL-P5663W 56" TV
Do you recommend Samsung DLP HL-P5663W 56" TV?
Answer
Answer
samsung tv just clicks when turned on comes on eventually
Answer
light area noted at center base of image when turned on - more prominent when image is black or... (More)
Answer
Didn't work for me! :( I have had the same symptoms for over a year, my Samsoung DLP 61in is about 3... (More)
Answer
i have a 50" dlp it wont turn on, it sems like its about to go on but shuts off after about a... (More)
Answer
i am seeing green static or interference with all av inputs and cable inputs. HDMI input says... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung DLP HL-P5663W 56" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
