Question about HP Photosmart C6180 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One Is printing All Documnets Faded Colors
MY HP Photosmart C6180 All-In-One Is printing All Documnets with Faded Colors. I originally had my printer connected to my laptop at home on Windows Xp. I recently moved the printer to my office which utilizes Windows Vista Business version. Now everything prints faded. When I used photo papaer the colors are a littel sharper but not as they were before. Is Vista causing this or is there a problem with the printer.
  • BBE1 Jan 04, 2008
    having same issue, worked fine before connecting to vist system, have already been through the system checks and resets with HP. mINE IS C6150 MODEL
  • j726m9302 Oct 31, 2008
    We just got this printer with all new catrages. All documents printed, in color, and black&white, are faded looking. But when I tried to just copy an image it came out much better.
  • 16 Answers
Try to clean your printheads or check the level of your inks, maybe you are low on inks. Operating system does not affect any printing outputs as I know. Check your inks also coz HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.
If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
Replace any empty print cartridges. To check ink levels, follow the steps below.
  1. Press the Setup button.
  2. Press the down arrow button until Tools is highlighted.
  3. Press OK .
  4. The Display Ink Gauge selection should be highlighted. Press OK and the ink gauge will display.
OR try calibrate the color:
  1. Open the printer Toolbox :
  • Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
  • If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
  • Click Settings .
  • Click Print Settings .
  • Click Printer Toolbox .
2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
If the steps above did not help, clean the print head.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Please let me know if these steps helped you or not. Thanks
Posted on Jan 05, 2008
After three hours they have decided to offer me a trade for a cheaper cost than replacement on the hp chat line, the above never worked i simply got yellow even with new ink. I was told the printer assembly was bad or the hardware as some of the functions in solution center didnt work either. thanks anyway....
Posted on Jan 06, 2008
Photosmart printer c6180, Color is faded?
I would first try a printhead cleaning operation.
This will clean the printhead to obtain the best printing possible.
Aug 15, 2014 | HP Photosmart C6180 All-In-One InkJet...
Can i print magnets on my hp photosmart C6180?
Your printer HP Photosmart C6180 cannot read Films or magnetic tapes etc.
Regards,
Suhail
May 17, 2012 | HP Photosmart C6180 All-In-One InkJet...
Magenta & light magenta not printing photosmart c6180
The ink level in the color cartridge has three different colors in it. You may need a new cartridge. Magenta is usually the first to go out.
Dec 14, 2017 | HP LaserJet Office Equipment & Supplies
HP C4280 won't print yellow
Right it does not sound like software More like part of the printer died
Jul 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 colors no good - missing colors & muted. No longer aligns print when requested, per HP note at end. Already cleaned print heads,[OK], aligned printer numerous times-doesn't work....
try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 Photosmart printer is not printing!
Unplug printer USB and reinstall drivers from printer disk.
If you have misplaced the disk, download the driver software from the link below:
HP Photosmart C6180 All-in-One Printer
Feb 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
Nov 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C5280 printer - 1 month old not printing correctly
Usually this problem is indicative of a clogged nozzle. I'm not sure about the track record of the Photosmart C5280 (a lot of Epson printers have this problem, and you just have to keep replacing the ink cartridges). I'm going to assume you tried this, but go ahead and run a few cleaning cycles on the printer, and see what happens.
Jul 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
2,021 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
