Question about ViewSonic VA1912wb Monitor
No sound VA1912wb
Lost all sound. Admittedly I was playing with buttons on Monitor at the office. User Guides are buried in storage in the attic. Whatever I did, I am not smart enough to undo. Would appreciate help. all other volume controls within the computer are turned up. Thanks.
  • 4 more comments
  • DerikJ Jan 07, 2008
    I have the exact same monitor with the exact same problem. One day it was working fine and then the next it wasn't working at all. I've tested the line from the PC with external speakers and there is audio there and I also noticed that when I switch the monitor to analog mode there is no display but the audio becomes audible. Of course because there is no display the monitor immediately flips back to digital and then the audio is gone.
  • BunnyHan Feb 12, 2008
    The sound from the monitor's speakers is very weak. I have checked the volume controls in both the pc's Control Panel and in the monitor's control panel. I am stumped.
  • kmaxson56 Sep 12, 2008
    Exact same as above. Change input and get sound with no display and then it changes back on its own. Would LOVE some help on this issue.
  • jarsenal66 Dec 08, 2008
    No Sound has anyone found how to fix this?
  • Anonymous Mar 16, 2009
    same problem
  • dfalardo May 11, 2010
    I have the exact same problem, has anyone found a solution yet? It's dring me crazy !
I have the same problem but after much playing around with the monitor controls I found that decreasing the contrast allowed me to hear the sound.... The more I decreased the contrast the better the sound became. To test it have a sound track playing and slide the contrast down (less) til the sound comes on. Mine was sporadic but the more I decreased the contrast the better it became. Ok you electronics engineers - tell me why. One draw back on my monitor is now I have raster lines running down the screen.
Posted on Feb 02, 2009
Never buy view sonic again....we've been scammed
Posted on Mar 31, 2008
Check the mute button on the bottom of monitor next to menu button.
Posted on Sep 26, 2009
Please help i have no sound in my monter speakers what do i do
Posted on Oct 08, 2008
I have a VA1912wb viewsonic monitor (A couple of years old). While playing any movie, the screen instantly goes black though the green light indicator is still glowing. Im able to hear the sounds from...
i think your monitor is going to expired soon , i u have valid warranty then try to contact service center if not then buy a new one LED monitor is best than LCD and LED has more life expectancy and woks very well so bye t.c
Sep 03, 2011 | ViewSonic VA1912wb 19" LCD Monitor
How do i get sound?
You will need an audio cable, cable with mini stereo headphone plug at both ends.
One end will go into the PC Audio line out (Green jack), the other end will go into the monitor audio line input jack (green jack).
Set the volume level on the monitor about 1/2 way up first, the volume control panel on the PC about 1/2 up also (wave, cd, etc 1/2 way also).
Then play some sound and adjust each level as needed.
Dec 24, 2010 | ViewSonic VA1912wb Monitor
What cable do I need to buy to connect my Dell computer to my ViewSonic monitor (VA1912wb) for sound?
You just need to get an audio cable with male stereo mini phone plugs (1/8 inch) on both ends.
Radio Shack: P/N 42-2497, 42-435, 42-436
Green jack to green jack.
Apr 01, 2010 | ViewSonic VA1912wb 19" LCD Monitor
I cannot get any sound from my ViewSonic VA1912wb Monitor. I have everything plugged in the mute turned off showing 100% volume the green jack in back of monitor and green match on computer. No sound from...
You may need to load the monitor drivers.
I assume your PC sound is OK.
When you are plugging the green lead in the Moniotr / PC do you hear any noise from the monitor?? if not may be faulty.
Try plugging a friends set of speakers into the back of your PC.
Mar 09, 2010 | ViewSonic VA1912wb Monitor
I pushed the button next to the power button now i have no screen, i pu7shed the button again but to no avail, please help
Common failure is the caps in the inverter/power board, look for caps with bulging tops, see example of failed VIEWSONIC monitor due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 23, 2010 | ViewSonic VA1912wb Monitor
My viewsonic va1912wb just flat-out died. Won't turn on, no lights, no response. Is there a likely cause, and is there anything user-repairable?
You have monitor with a very common problem, a dead power supply. After 2-3 years many LCD monitor power supplies will fail just like you have described. The problem is caused by parts called capacitors overheating in the tight space of the monitor case. If you can solder then you should be able to do the repair yourself. We will have a repair guide posted 12/29 after about 5:00 central time that should get you back going again. The repair guide will be on our web site at: www.ccl-la.com If you have any questions please let me know at the address below.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 29, 2009 | ViewSonic VA1912wb Monitor
No sound
Have you connected the supplied lead(s) from your monitor to your sound card?
If this helped please vote
Oct 09, 2009 | ViewSonic VA1912wb Monitor
ViewSonic VA1912wb 19" LCD need sound driver
operation174 -
Here is the driver download page for your monitor:
http://www.viewsonic.com/support/downloads/drivers/?prod_name=VA1912wb
Choose the correct download for your operating system.
Thanks,
videoman7
Aug 07, 2009 | ViewSonic VA1912wb 19" LCD Monitor
White screen, power switch not functioning.
Unplug it, reset it. Did it come with install disk? Try running that with your old monitor. The system may not recognize it as plug and play or the monitor may be defective. Call Tiger Direct or whoever you bought it from for support.
Jun 24, 2009 | ViewSonic VA1912wb 19" LCD Monitor
ViewSonic VA1912wb Monitor Logo
1,348 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
