Question about Sony Handycam DCR-PC101E Mini DV Digital Camcorder
Cannot load tape into pc 101
When I load the tape and close it, it doesn't drop down.  I have had the camera repaired for this problem in the past and don't want to go through the time and expense for this.  any solutions?
    President:
  • 4,402 Answers
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jan 21, 2008
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
Everytime I load a tape and close the interior casing after about 10seconds the cannon starts bleeping 6 times and ejects the tape. I also listened closely to hearing else and there was a very faint...
This is a tape transport malfunction and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Aug 15, 2011 | Canon Video Cameras
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
Canon camrecorder will not load cassettes take
Believe it or not, but I found a possible solution for that in another forum. The suggestion was, to let the camera drop from about 0,5 m height onto the floor. Make sure, that there is a carpet underneath, which prevents the camera from severe damage.
This is no joke - I have let it drop once and the cassette was loaded and everything worked fine. There might have been a sensor problem or a little hickup in the mechanic.
Try it on your own risk - but what do you have to loose ? I wanted to sell the camera as broken on ebay, but now, I have a running camera again.
May 15, 2010 | Canon MV800i Mini DV Digital Camcorder
Canon ZR200 -- I can no longer get the camera to accept a tape.
it could have been forced at some time and has bent the loading door,,, maybe a bit of cassette broke off inside it and is jamming it up best bet is to drop it off at the repair shop let them fix it for you,,
Oct 27, 2009 | Canon ZR200 Mini DV Digital Camcorder
Sony video8 won't accept tape (door won't finish closing)
Sony DCR HC 42
I have the same problem as gskillman
Sony says it qualifies for a fla rate repair -- $201 plus taxes!!! Say what? This camera is only a couople of years old and has hardly ever been used.
Jan 11, 2009 | Video Cameras
Canon ZR 600 tape won't load
The capstan motor is broken and needs replacement. You could send it in for repair but it wouldn't be cheap.
Dec 31, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Tape not loading
Drop it on a carpeted floor from half a metre
I got the solution fromFixYa on 3rd Feb 09 it worked for me
Dec 16, 2008 | Canon DV-MV830i Mini DV Digital Camcorder
Tape not loading
I READ THE SOLUTION TO THIS PROBLKEM THIS MORNING ONTHIS WEBSITE, BUT I CAN NO LONGER FIND IT.
THE SOLUTION SUGGESTED DROPPING THE CAMERA ON TO A CARPETED FLOOR FROM HALF A METRE HIGH AS A FIX.
THERE WAS ALSO A POSTING FROM A GUY WHO HAD FOLLOWED THIS ADVICE AND IT FIXED HIS CAMERA.
SO I DECIDED TO FOLLOW SUIT AND I DROPPED THE CAMERA ON TO A CARPETTED FLOORT FROM HALF A METRE HIGH AND WHEN I TRIED IT WITH THE TAPE IT WORKED, NO JOKE, THIS IS AN HONEST AND TRUTHFUL REPORT.
REGARDS
EDDIEWEST
Mar 15, 2008 | Canon MV800i Mini DV Digital Camcorder
Sony Handycam DCR-PC101E Mini DV Digital Camcorder Logo
56 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
