Question about Garmin StreetPilot c550 GPS Receiver
Turns off after a few minutes
Plugged into usb over night, made it stay on for about 10 mins , then keep on turning of progressively less time. I guess battery is low and getting worse. I tried plugging into car lighter and same thing . I dont know why it will not run for ever if plugged into the lighter?
  • antonym Jan 03, 2008
    After closer inspection It looks like the copper connecter plug wire may be touching each other , not 100% sure . Im going to exchange it for a new one . That sure fix it !
  • connellyMB Jan 05, 2008
    My Garmin Unit C550 is charged through USB, but its on & off when it plug into car adapter. Not sure whether its the car adapter that is broken or the connector to the unit. Its so annoying happen twice already. it become highly unreliable as when we need the most on the road, it just dies and wont be ON no matter what we do. Have reported the problem to Garmin International and still wait to see what they say. If anyone has solution please share. Thank you.
Have the same problems, can't figure it out yet
Posted on Jan 03, 2008
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
How do you keep the night sky projection clock on permanently? The display stops projecting after a few minutes. I know it used to stay on all night but I lost the manual
First, keep in mind that the unit shuts down to preserve battery life. Simply remove any batteries to be sure the unit won't accidentally run on them and activate the 10 minute auto-shutdown. Keep the AC adapter plugged in at all times for a continuous projection. If you don't have the AC adapter then I'm afraid you're out of luck. Perhaps check eBay for one, but you will need that cable plugged in if you want the projector to stay on all night.
Mar 06, 2011 | Uncle Milton Night Sky Projector Clock
MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Aug 02, 2009 | Whirlpool Dryers
My Tv is turning off by itself
unplug and let sit for a min then plug back in
Jan 01, 2009 | Televison & Video
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv powers on, but turns off after a few min
somone with some sort of tv knowledge told me that sometimes people dont realize t but moisture builds up inside and it needs to be dried back out
Jan 28, 2008 | Televison & Video
Pioneer PDP-4330HD - turns iteself off - resets
I bought a 503 which had this problem, it would stay on for anything between 10 mins & 3 hours.
the guy told me he had been told it was a condensation sensor.
All I did was take back off, blow it out all boards with an air line, disconect fans. I ve had it 6 months now with not a single problem.
Jan 08, 2008 | Pioneer PureVision PDP-4330HD 43 in....
Loss of Power
You might want to unlpug the powercord for the night, then plug it back in the next morning. Some times that can help reset things. If that still doesnt do the trick, you might have a faulty power cord. If it does this with every source you hook up to your TV then that would be a sign that its something in the set vs. your external source.
Dec 02, 2006 | Samsung HLN4365W 43" Rear Projection...
Garmin StreetPilot c550 GPS Receiver Logo
59 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
