Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony 38' Wega trinitron
Just got this TV days ago from a friend,standby light is on and the TV wont turn on,tried pulling the plug and using the remote same result!
  • mgpl Jan 03, 2008
    Same as above happend today
  • mgpl Jan 03, 2008
    same as above happened today
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
try checking the soldered joints on the main circut board that attach the larger metal components...I re-soldered aprox 40 connections and now the tv works great!
Posted on Jan 31, 2008
  • 116 Answers
SOURCE: Sony FD Trinitron Wega
The power supply board is failing. There are twi integrated circuits in the horizontal drive circuitry that have to be replaced. The original integrated circuits are the same type and you will see written on each..."MCZ3001D" and need to be replaced with Sony # 670581001 or the "D" board with those parts on it needs to be replaced. The cost of the entire board is high-about $375.
Posted on Mar 01, 2008
SOURCE: Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Posted on Dec 01, 2008
  • 106 Answers
SOURCE: Sony FD Trinitron WEGA KV-34HS510 34
  • Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board). This may help !!
Posted on Mar 24, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Why wont my Sony trinitron tv turn on but stand by light flashes?
That Flashing Standby Light Indicates A Defect In Your Low Voltage Or High Voltage Power Supplies...
May 25, 2014 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony trinitron tube tv Standby is flashing and the tv wont turn on
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 06, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron not working
The power supply has failed which are very expense and your better off Getting a new T.V.
May 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Standby Light
maybe the vertical ic is defective.resolder it first if you have experience.then power it on.post back if theres no outcome.u
Jul 12, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Please post the blink count. The standby light should be blinking a repeated count. That will indicate the circuit where the problem resides.
Thanks,
Dan
May 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
