refrigerator the freezer is cold but other side is not, when I have the freezer door open cold air blows through the vent to the other side through the vent
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the tope of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working Ok then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Also worth checking the return air path from the fridge and making sure it is not blocked or frozen up. Also check the freezer compartment and cooling panel at the rear (behind the cover plates) and the fan for icing / blockage up as it sounds like there is a mini vacuum being created when the freezer door is closed or you have too much in the frezer so it presses on the back plate and stops the mini fan circulating air to the fridge.
when you open the freezer door do you hear the fan blowing if you don't you have a bad evap fan motor
Comments:
Nov 05, 2009
- the freezer feeds the refridgerator side with cold air,the evaperator fan blows the air to circulate it throughout the fridge through the air ducts,you say when you open the door the air blows to other side so ducts shouldn't be blocked,can you give full model number so i can look it up
Was this helpful?
Yes
No
Popular Solutions for Kenmore 55612 / 55614 / 5561 /
Have GE PTC22 model top freezer fridge. Water dispenser stopped working. When I pushed the dispenser...
(More)
Have GE PTC22 model top freezer fridge. Water dispenser stopped working. When I pushed the dispenser water came out of the bottom of the fridge on the floor. Determined that the issue is not from the front water lines. Need to figure out how to get to the line from the back. There is a very small opening can just see compressor and fan. Is there another "magic panel" that can be removed? Repair person wants 80.00 to walk in the door and $125 hour labor. Note: Ice Maker works without issues so problem is after the split.
the water dispenser will work but when I release the lever the water continues for 10 sec until it...
(More)
the water dispenser will work but when I release the lever the water continues for 10 sec until it runs out of pressure
kenmore 106.53606202 last few days fluctuates between working ok, freezer freezes, then fridge and...
(More)
kenmore 106.53606202 last few days fluctuates between working ok, freezer freezes, then fridge and freezer are both warm don't work at all. repair tech removed grille on bottom and said it doesn't feel right, the evaporator is leaking freon and it is not worth repairing. we are ready to replace it but don't feel sure about diagnosis.
