Question about IBM ThinkPad T40 2373 Notebook
IBM THinkpad T40 not charging
A while ago, i made the power jack external because the wires were broken. I used like that for quite some time without ant noticeable problem. One day, i noticed that one of the wires was really hot and was not charging (I believe that i inverted the cables, brown with the white). Since then, it is not charging the battery and is not working as an AC power ? Consequently is not starting. I do not have an extra charged battery to test the computer. Is there a fuse somewhere that i blowed? thanks cesar
    Champion:
  • 238 Answers
Hi, since u say the wires were hot , that means -ev and +ev got shorted, that might have damaged the power supoply, or the polarity is reversed,if u can manage to open the adapter, then try replacing the fuse if present , and the filter capacitor. let me know
Posted on Jan 05, 2008
How do you take out T42 IBM broken power jack in order to put in a new one
you need to remove the keyboard then the upper casing... if you have a modem, remove it to get more work room. you should be able to unplug the power connector off the mainboard (the wire between the power jack and the mainboard) and snap the old jack out of place. be careful not to break the board or anything while doing so, though it should not be hard to remove the jack since it is not soldered. best of luck
Jan 25, 2011 | IBM Laptop DC Power Jack for Thinkpad T40,...
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
Will not power up, tried switching batt and a/c adpt. Like the on/off button does not work
You may have a problem with the input power jack. The jack itself maybe open and does not provide power to charge the battery or power the computer. The laptop must be disassembled to check and/or repair the jack. Try getting the battery charged from another similar laptop and then see if the laptop powers up - if it does, the problem is the jack. Worst case is a bad motherboard.
Oct 28, 2010 | IBM ThinkPad T40 2373 Notebook
Hello, I have an IBM ThinkPad t40 and my battery will not charge. It runs on AC power but shuts off as soon as AC is removed.
You should replace the battery. I wish I had a better answer, but that's pretty straight forward.
Mar 04, 2010 | IBM ThinkPad T40 2373 Notebook
Probleme power ibm thinkpad t40
Check your Battery if it take charge. Then check if ever your laptop start without the battery.
Feb 15, 2010 | IBM ThinkPad T40 2373 Notebook
Power connector of T40 think pad loosen
if you think your adapter really works fine then you have a  motherboard issue.
May 28, 2009 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad R40 No PowerUp
If the the ram is the problem of your system, there should be a power on light on the system. indicating that some of the component of the system is not working correctly. But since you mentioned there is no light, it is the possibility that the problem is the motherboard itself.
Feb 26, 2009 | IBM ThinkPad R40 2722 Notebook
IBM,lenovo ThinkPad R31
Maintenance manuals for both systems are on www.lenovo.com/support, under the publications section. But without looking at it, I would say no, the cables will not work.
Jun 09, 2008 | IBM ThinkPad R31 2656 Notebook
My IBM do not turn on.. IBM A21M..
check power ac adapter and batery if the batery is ok or charge do a test to the hard drive and memory ram loock on BIOS
Jan 03, 2008 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad T40 2373 Notebook Logo
436 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
