ASUS P5GD1-VM Motherboard
Boot hang after formatting of hard drive
posted by VinBop1 on Jan 02, 2008
I bought a Maxtor PATA 160GB hard drive for my ASUS P5GD1-fms system. Installed WindowsME. ME does not support HD over 137 GB but I limped along with only 20 some GB recognized. All worked fine. Thought I'd reformat the drive into a couple of partitions thinking that it would work OK with 2 80GB partitions. Now when I attempt to boot, the system hangs. With a Windows 98 startup disk, the floppy is accessed for awhile then stops. With the Maxtor Bootable CD, the drive is accessed for awhile and then stops. No prompt or warning messages.
I reset the bios to factory defaults - no improvement.
cleared RTC RAM - no improvement.
The boots do not hang if I have disconnected the HD.
I think I goofed something up on the format that causes the BIOS problems. I'd try formatting again but I can't get anything booted to perform the format if the drive itself is connected. There must be a BIOS setting that would allow me to get booted enough to reformat the drive?
Comment posted on Jan 04, 2008
Thanks for the response! Formatted the HD on one of my other computers and problem solved.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 02, 2008
FixYa! (100)
DARKLORD1
Rank:Guru Guru
Rating: 85%, 424 votes
no there isnt, you need to take it and put it in another computer as a slave drive. But you might have damaged your hard drive, you can try Hiren's boot cd from here www.phazeddl.com but personally i think you might have messd up the drive.
to install as a slave
1.) find a working computer
2.) put hd in as slave (do not remove old hd)
3.) boot
4.) it will show up in my computer
5.) format and unmount drive
it the computer fails to boot ensure you got the drive connected propperly and jumpers are correct
it thats all good then your drive is damaged
Rating Locked! (?) VinBop1 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on boot hang after formatting of hard drive:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Motherboards
SiS 760 Display Adapter not functioning. I also have...
Hi Jeff, I think you may be getting somewhere. Just...
Mercury Chipset Mother Board Number : BT8237R+ Problem is...
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
