GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZISS480DMCS Ice Maker Problem
posted by Optimistic on Jan 02, 2008
We have a GE Monogram ZISS480DMCS ss side-by-side refrigerator with ice and water through the door. The ice maker light is on (green). The auger appears to work fine and is free of obstruction. The water reservoir that makes the ice is dry and very cold to the touch. The ice maker is not receiving water, but we still have water through the door. How can I fix this?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 24, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The water solenoid valve should have 120v going to it. (You will need a multimeter to chk this). You will need to also chk. for proper ground when verifying the 120v. If you get 120v on each of the pin clips, then your plug is not properly grounded, which means that you need a new ice maker circuit board. This is located in the in dispenser (front panel opens).
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on GE Monogram ZISS480DMCS Ice Maker Problem:
I don't want to Accept this solution
Solution #2
posted on Jan 02, 2008
Not Rated (0)
williej
Rating: 0%, 0 votes
Check and make sure that the float arm in the ice bin is down and able to swing. This arm should be down until the bin is full of ice which would raise the arm and stop any water flow until ice cubes are removed, and allows the arm to drop again to start the cycle all over again, to replace the ice that was used. The arm has a spot to snap in and be held where it would be in a position all the way raised, to allow the bin to come out for cleaning or all of the ice removal from the bin, such as to dump the ice in a cooler. The arm should be gently pulled down to hang freely and will slowly raise on its own as the bin fills with ice.
Thank You!
Can you Help with these Refrigerators problems?
We have a GE Monogram ZISS480DMCS ss side-by-side...
When you go to get water in a cup, it starts out cold and...
Just suddenly stopped making ice. It's turned on, makes...
is there
Trying to remove grid in order to clean coils. Took out...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
