Home | RCA | D52W19 52 in. Rear Projection Television | RCA HD56w66 turns on and...
RCA D52W19 52 in. Rear Projection Television
Problem for RCA D52W19 52 in. Rear Projection Television
RCA HD56w66 turns on and off three times...
By ace9139095 on Oct 30, 2009
RCA HD56w66 turns on and off three times... replaced cap 114 120 and 150 turned on tv it turned on and off and then popped cap 120. What can i do?
Comments:
Oct 31, 2009
- you were absolutly right the polarity was backwards on cap 120...now it turns on and off three times and a chirp sound is coming from back of deflection board. any suggestions?
Nov 03, 2009
- thanks i located the (HOT) is it possible that my flyback is still good or would the HOT of taken the flyback with it?
Best Solution
posted on Oct 31, 2009
Helpful)
Slinteriors
Rank: Guru  RCA Televisions & Videos  Expert
Rating: 89%, 3664 votes
Was cp120 installed with the correct polarity? Also was the microfarads the same as the original? Voltages can be higher but the Microfarad (uf) rating has to be exactly the same.
Comments:
Oct 31, 2009
- It may possibly be that the HOT has shorted due to the CP120 reversed polarity. The hot is the 2SC5588 transistor mounted on the large heat sink directly in front of the Flyback
Nov 03, 2009
- Its very possible that the Flyback is defective, As the ITC 222 series are famous for the failed caps and also the flybacks and HV splitters being prone to failure . The Hot can be checked with a ohms meter if removed from ciruit for testing. The flybacks and HV splitters are available for those models. But often its usually cheaper to have your deflection board rebuilt since new replacments arent available. Rebuilt boards solve the issue and are guaranteed for up to six months from most rebuilders.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for RCA D52W19 52 in. Rear
Questions and Unsolved Problems for RCA D52W19 52 in. Rear
Do you recommend RCA D52W19 52 in. Rear Projection Television?
Answer
Answer
RCA D52W19B does not tune to all channels except channels 14&15 on cable tv. All channels... (More)
Answer
I have a desk top PC that i'm wanting to connect to an RCA televison D52W19 to a DVI input the... (More)
Answer
tv rca d52w19 power light blink 3 times doesn't turn on
Answer
I have a RCA D52W19 when tv turn on the power light blink 3 times but nothing hapen
Answer
My screen keeps automatically adjusting size and i cant control it. what do i do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA D52W19 52 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
