Dell Latitude D600 PC Notebook
Problem for Dell Latitude D600 PC Notebook
Blue screen says i need tech support
By uniandfati on Oct 30, 2009
My dell d600 has a blue screen and is telling me that it is dumping all physical memory and that i need tech support what should i do?
Clarification Request
Posted by Dageezer on Oct 30, 2009
Post the stop error code of the blue Screen if available.
Solution #1
posted on Oct 31, 2009
Not Rated)
Kegtapper
Rank: Guru
Rating: 87%, 118 votes
Read the complete solution please-
Depending on what the error says you may not need to contact technical support. Often this happens when the swap file becomes corrupted and since it is used as virtual memory, the OS assumes it is RAM that is defective. So it generates a system level error.
To correct this....
See if you can start in SAFE MODE, go to System Properties
Select ADVANCED tab
Select PERFORMANCE settings
Then Advanced tab again
You will see Paging File Size in the middle.
SET/Change this to 0 (zero) NO PAGING FILE
Select OK to continue
No Paging files for all drives if you have multiple partitions (logical drives)
Then save/ok your settings.
Then REBOOT
Repeat the above process and set the swap file to 2-3x the amount of ram you have in your system.
Or simple select the System Manage Size button.
(example: 1gb Ram = 2gb Virtual Memory)
Save setting and reboot again.
1: Why do I have to Reboot after each time?
because the system removes the swap file writes the changes to the registry.
2: How did my swapfile get corrupted?
sometimes a bit/byte get lost because of improper shutdown, power loss, badly designed programs, trojans and a number of unexpected issues.
3: Do I need to buy more physical ram?
only if you are using less than 1GB (with XP) or
2GB with Vista.
Good Luck
Was this helpful?
Yes
No
Popular Solutions for Dell Latitude D600 PC Notebook
Questions and Unsolved Problems for Dell Latitude D600 PC Notebook
Do you recommend Dell Latitude D600 PC Notebook?
Answer
Answer
Monitor goes black (no green, no to flashlight test) even while we are working at fast pace and... (More)
Answer
Auxiliary monitor periodically goes black while still working. Wiggle mouse and it comes back up.
Answer
It just wont work, it does read some cds but will not download programs or burn etc...
Answer
trying to get on texas holdem stops half way
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , MD
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
