Question about Maytag CWE5800A Electric Double Oven
Maytag "Magic Chef" electric double wall oven
We purchased our double wall oven in 1995. Love it. After cleaning it last weekend, we went to use it again. Cannot broil or bake -- the message says "door". We did not open the door during cleaning or improperly unlock it. In fact, we waited one hour after the cleaning was over -- and the "lock" light had already gone out prior to finishing cleaning -- before we opened it. Nothing. We even took the door off and slid it back on. Still can't get it to work. Top oven only. Bottom oven works fine.
Check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Posted on May 19, 2008
Magic Chef wall oven does not turn on after there was a fire in the oven.
I would get an appliance engineer to check/repair it, if a repair is possible.
May 06, 2017 | Ovens
Magic chef wiring connect
Hello Kym....I know you may want to try this electric oven is a high voltage device..usually 220 volts...and if you are not equipped to directly connect this....PLEASE have this done by a professional....Don't try this...This is not a it yourself project...I hope this was helpful.......PEACE....
Feb 09, 2012 | Magic Chef 9522 Electric Double Oven
My oven will not stop beeping F 1. It's a Magic Chef wall oven. Electric
Thanks for using FixYa. Error code F1 means failed thermistor/transistor in control. To resolve this issue you'll have to replace the Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Oct 08, 2010 | Magic Chef 9815 Electric Single Oven
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
Sep 13, 2009 | Magic Chef 9815 Electric Single Oven
Magic chef manual
You can download it here but you need the right model #.
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
Dec 18, 2008 | Magic Chef 9522 Electric Double Oven
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Magic chefa313-230lw gas ignitio
hi .thanks for the question . A very common problem with gas ovens replace the igniter thanks the appliance doc
Sep 29, 2008 | Magic Chef 9512 Electric Single Oven
Error code F1
I had the same problem and found this post:
The oven had been cleaned earlier in the day and the touch pad ribbon connector was shorting. I cleaned it with rubbing alchohol and blow dried the whole board for good measure. Hooked everything back up and haven't had a problem since.
Jun 08, 2008 | Jenn-Air JJW8230D Electric Double Oven
Maytag CWE5800A Electric Double Oven Logo
583 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
