Question about Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR-ES40V This recorder is about a year old. I have used it only once but it may be out of warranty. The unit does not turn on. I have unplugged it and tried to reboot the unit. Got a message of F60. Called Panasonice but they said to send it to them. If it is out of warranty this will cost a lot in addition to what I have already paid. What ever happened to Panasonic quality?
Benimur
  • 6966 Answers
SOURCE: DMR-ES40V Error Code F03
If I may add to JoshOHoward's posting and with his indulgence.
The F03 (Fault 03) error indicates possible problem with your DVD's mechanism, specifically the either the spindle or the transverse servo drive. This is the motor and drive mechanism responsible for moving the carriage that contains the optical reader/laser eye forward and backwards.
What perhaps you can try:
1. do a soft reset. With no disc, press and hold the power button for more than 10 seconds. Alternately, you can unplug the unit for an hour or so.
2. Do a force initialize. With no disc inside, eject the tray, close the tray simultaneously pushing on the back skip, pause and play buttons
3. Do a full hard reset. With the unit powered off, press and hold the Stop and Channel Up buttons while powering on the main unit at the same time for about 5 seconds.
If the above does not prove to be corrective of your concern, pls post back since further diagnosis/repairs require opening the unit.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 13, 2008
SOURCE: Panasonic DMR-ES40V, error codesF60 & U99...
Same problem. Contacted Panasonic. Technician indicated that there is a problem between the CPU and the timer. The unit is three years old and out of warranty, so he offered Panasonic's service at $120 for labor plus any parts.
So I gave it one more try. I pressed and held the REC on the Power button for about 10 seconds, which reset the unit. Then I was able to play a DVD and eject it.
Hope this helps with your unit.
Posted on Dec 01, 2008
SOURCE: F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Posted on Jul 22, 2009
SOURCE: DMR-es40v f60 error
Problem for Panasonic DMR-ES40V DVD-Video Recorder with Built-in... Maching displays F60 as soon as it's turned on and
Posted on Jan 03, 2010
steven_mower
  • 9 Answers
SOURCE: F60 ERROR CODE ON PANASONIC DMR-ES40V
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
Posted on Jul 21, 2010
Panasonic DMR-ES40V VCR won't schedule record: Recently, the VCR will not do scheduled recording anything beyond today. I can schedule a recording and it appears OK (I get red light on panel), but I never...
I found this solution on one of your old notes (but a different machine). I set up a scheduled record for 11:59 PM to 12:01 AM for the current day, then set up the scheduled record for the next day. The VCR recorded both the initial 2 minute session and the later one which I wanted to record.
Dec 27, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
DMR-es40v f60 error
Nov 13, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR ES40V Err message, DVD won't play or record
I had a similar ERR message and freaked out a bit for a week. Panasonic customer service was no help and suggested i send it in for VERY expensive repair. No way. After tons of additional research and trouble shooting I fixed my unit tonight. I downloaded the DMR-ES40 DVD Recorder Firmware Update from the Panasonic update and stored in on a CD. Put the cd in my dvd player following instructions from the website. My system is restored and works well again.
Why paid personnel at Panasonic could not tell me this is beyond my understanding.
Try updating you firmware as I did. Hope you get the same success. -Tamara
Dec 11, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
RDVD won't record
Dear Valued Customer,
Thank you for your inquiry, reguarding model DMR-ES40V.
Try this reset to fix the issue.
1. Unit power must be on.
2. Press [STOP] & [VHS > DVD] ON THE UNIT for over 5 seconds.
Thank you for contacting Panasonic.
Thank You,
Panasonic Consumer Support
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/CustomerSupport?storeId=11251
Nov 26, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic ES40v - Can't play DVD's - Incorrect region
I had the same trouble, also wouldn't play back discs that I recorded using it. The commonly listed reset of channel up and down at the same time was not meant for this model.
Below is the official solution that was sent to me by panasonic.
After using this method to reset my player it worked great. it was just like taking it out of the box for the first time.
Thank You,
Nov 02, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DVD Recorder
We need to narrow down where the problem lies. Even without finalizing the disc, you should be able to play back the recording. Can you do this? If you can play back the recording, the problem exists in the finalization stage and we'll need to concentrate there. Pplease update this and we'll proceed to the next step.
Thanks,
Dan
Sep 07, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Jul 21, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Televison & Video Logo
156 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
