Question about Nintendo Wii Console
Hook up I have a Hitachi HDTV, my cables run from my receiver to TV and then the cable box.... what is the correct hookup for the Wii, I also bought the cables for HD.
  • Anonymous Nov 28, 2008
    I am having trouble hooking up the nintendo Wii to my Hitachi plasma TV - can you please help.
  • 310 Answers
Hi, im using a HDTV with my wii, but im just using the standard cables ie, wii - skart connection , one to wii sensor, and one to mains plug from wii,
and works fine..
All the best
Posted on Jan 02, 2008
No sound coming out of speakers tuner or cat/tv
Please add details of setup so I can help you. For example. My Directv box hooks into my HDTV HDMI. Sound is carried inside that cable. I then get sound on my TV from my Directv RCVR without any other hookup. But I do have more. I use an optical cable to go into my Denon 1312 TV/optical input. Since my Wii, PS3, VCR, and formerly Xbox360 all plug into the HDTV inputs and I use it to switch. The Denon is not HDMI capable so this is best for me.
This is the first thing I would try. hook the HDMI to your HDTV from the CATV/SAT box and turn up the sound on the TV. [Box and TV on and correct input used] If you hear audio, the hook it back up as before. Now, turn on the Denon to radio. and turn it up. Got sound?
NO: check speakers and speaker setting. Let's say you have speakers hooked to A but not B. is the selector on B or AB. That won't work. It has to match the hookup. If speakers are on A only, select A only, etc. Also check with known good speakers. Also check all cables to be plugged into the correct spot and plugged in fully.
Thanks PM me if you need more help.
Aug 07, 2014 | Denon AVR-1601 Receiver
Got the digital set up box from Time Warner Cable but they did not include hook-up instructions.
If you have an HDTV, you can hookup HDMI cable from set-top-box to the HDTV's HDMI input and select that input on the TV using your remote. If you have analog TV, you can hookup using RCA cables (yellow to yellow, white to white). You could also call Time-Warner for assistance.
May 16, 2011 | Televison & Video
Won't to hookup a wii to a cable box and tv
Generally you do not need to hook the wii up to a cable box, simply plug the Yellow, Red, and White cables into the same colored plugs on the back of the tv. If this is not the problem please be more specific.
Mar 20, 2011 | Video Game Consoles & Games
How do I hook this up to a COMCAST Cable Box...or do I hook it to the audio of the TV? Are cables the best or should I just buy an HDMI cable?
Cable (and any source) audio should go digitally and directly to your AV receiver. HDMI would work, too, but the TV would be the best place to send the HD video if you only have the one HDMI output at the Comcast box.
OTOH, I compared both HDMI and the component video hookups to my HDTV and could not see the difference. So I run my BD on HDMI (because it is by FAR the best video the TV will ever get) and component video from the HD cable box to the TV (because all broadcast video is bit- and bandwidth-limited somewhere along the line).
TV audio almost never originates with the TV unless it has an antenna, so why would you want to feed its audio to the receiver?
Aug 19, 2010 | Audio Players & Recorders
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
Apr 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
How do you hook up the wii to the HItachi UT 42 x 902?
Problem: Hooking up Hitachi UT42X902 to a Wii
Solution: Even few technicans understand the issue because they have a hard time comprehending the Hitachi UT42X902 Director Series only has 1 HDMI jack and no RCA connections. I have both a Wii and UT42X902. At one point when I had a 4-way call with Hitachi, Nintendo, and Onkyo trying to figure this all out. So after several miss-steps, here is what I did and it worked…
I ended up buying an Onkyo TX-SR606 AV Receiver Amplifier-Tuner which has "uplink" capability. (Do not buy the TX-SR506 or other Onkyo models they do not have the right uplink capability to work the Wii on the UT42X902 Director Series, I already made that mistake and the store would not take the 506 back by the time I got everything I needed to connect the system.) I then bought a off Nintendo market Red/White/Blue/Green/Yellow HD or HDMI compatible (for the Onkyo side) on one end and Wii compatible on the other (sorry I don’t remember the technical name for the cable but they are pretty common and Best Buy and other electronics stores have it). I connected the cable to my Wii and the 5 ended side of the cable to the Onkyo. My CATV satellite box and DVD player are also connected to the Onkyo with Monster 1000HD (10.5 Mbps) HDMI cables. The Onkyo is connected to the Hitachi UT42X902 also via a Monster 1000HD (10.5 Mbps) HDMI cable. The Wii works perfectly with this setup. You may have to go into some menus to set up the sound (I do not have external speakers yet). Good luck. I usually am not on this site but will try to monitor this site every few days for the next few weeks so post is you have questions, and I will try to help.
Disclaimer: I am not a TV tech and do not sell, represent any TV, Receiver-tuner-Amp, websites, cables, TV channels, services or other related products, nor do I own stock in any of these companies. I am a mere mortal girl who wanted to use her Wii Fit on her big screen TV.
Jan 02, 2010 | Hitachi Director''s Series UT42X902 42 in....
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Dec 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
You will need a Digital Optical cable to hook it to the JVC. You should use a Component video cable to hook it to the TV.
Sep 11, 2007 | Arris DCT6200 DTV Receiver
Nintendo Wii Console Logo
249 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
