Question about Toshiba 40H80 40" Rear Projection Television
Only part of pic when first turned on and pic comes back after tv is warmed up
  • Anonymous Feb 15, 2008
    BLACK BOX ON SCREEN
  • Toshiba Master
  • 8,617 Answers
Can you describe in more detal on what you mean by part of picture?
Posted on Feb 09, 2008
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
May 13, 2017 | Sony Televison & Video
When tv is turned on, only half of pic is there (left side)..The right side looks like a bar code, with horz. and vertical lines..There is color behind these lines....After it warms up or a couple hours...
This tv is a standard CRT(tube tv) wright?Yes,than the tv video board have problem with dying capacitors or the main colors decoders IC require resoldering.U have a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders and also understanding basic electronic wright?Take the tv aparts check all those capactors all around the main colors decoders IC for capacitors leakages,replaced all these dying leakages capacitors,will solved this problems.These capacitors alway bulges up or puffing up on it top.That the indication those capacitors are dying and not working to it full capacity.Also resolders the colors decoders IC too.Ur tv problems,will be solved.
Nov 15, 2010 | Sylvania Televison & Video
1. After being on for 1-2 hours the pic goes out and turns to "the green screen of death". Pic will not come back on unless TV cools for 30+ min. 2. When I switch from DVD source to cable TV source the pic...
You got an issue with overheating.  TV is designed to shut off to protect electronic components if TV overheats.  Take it to the shop and have them open this thing up to identify the faulty circuit.  Also, check to make sure your not blocking the heat vents.
Nov 11, 2009 | Hitachi 70VS810 70" Rear Projection HDTV
Hitachi 42EDT41A Plasma (Snow, very light pic), all else OK
LCDs are worth it to have as to a Plasma set as plasma tvs do need time to warm up LCD and LED tvs dont have that warm up time to wait for things to smooth out however if you wish to have the tv serviced it is fully up to the owner of that TV now mind you there is also OLED tvs out there in the market as well and with the cost of LCD tvs going down to about 500 bucks you might be more interested in that but thats my IMO on buying a TV set
Mar 02, 2017 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Set dont like to be cold
Resolder all pinns on FBT on the Deflection board.
Jan 16, 2009 | RCA D61W20 61" Rear Projection Television
When set cold it doesnt have pic
check capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is Bad so replace other 2 as well.2200uf 16v and Two 220uf 35v.
Jan 15, 2009 | RCA D61W20 61" Rear Projection Television
T.V. would take about an hour to warm up.
I have answer serveral times about this ck 3 capacitors on deflection board.cp150- cp111- cp114
Oct 02, 2008 | RCA D52W19 52" Rear Projection Television
My Sony T.V 2000 model# KV-32XBR400 Is a great T.V we love the size and Pic. the problem is when you turn on the T.V it goes to standby mode and no pic will come on. If you move or shake the large T.V....
There are bad solder connections inside that should easily repaired. If you can solder, you can fix this yourself. Look for solder joints that appear grainy or have rings and resolder them.
Keep us posted.
Dan
Aug 22, 2008 | Televison & Video
Sansui tmv1916 tv no pic
have a sansui tv with a date of sept 2002 i bought the tv because it was on sale and have since lost the reciepts. anyways , no i need the tv and when powered up there is no picture but the sound comes on fine. i turnd it upside down and beat it and shook it and the pic came on for a min only to turn back off in 5-6 minutes. help. oh and i dont have electrical or circuit knowledge but willing to change a bulb or fuse. as you say that sound is ok and picture also comes some time so please check loose contact in luminance section of chroma ic . weak signal may cause rolling and intermittant picture problem for that checkloose near antena socket thanks
Sep 10, 2007 | Sansui TVM1916 19" TV
Toshiba 40H80 40" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
