HP LaserJet 4250n Printer
Ink smudges off envelope
shared by 2 users
posted by yeg27 on Jan 02, 2008
when printing on envelopes the ink smudges off and fingers ger dirty
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by bjp67gto on Jun 19, 2008
I have and HP Laser Jet 4250N and am having a problem with the envelopes smudging when using tray 1. I have replaced the fuser and have tried different envelopes, but still have the same problem.
Best Solution
posted on Jan 06, 2008
Helpful (85)
jaylex
Rank:Guru Guru
Rating: 85%, 344 votes
You will need to select in the drive that the media type you are putting in is envelopes this will adjust the printer fusing section to increase the heat.
Also you must select to go through tray one when doing this open the back door and the printed envelope will come out of the back and should be fine. If not try a lesser grade of envelope if still the same problem then the fuser unit is slipping and will need to be replaced.
Hope this helps you
Thanks J
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ink smudges off envelope:
I don't want to Accept this solution
Solution #2
posted on May 22, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Guys,
I did that already, I replaced fusing assembly. Also, I did modify the fuser mode for the envelope and still wouldn't work.
Best Regards,
Karol Wysocki
karolw@bbhinc.com
Thank You!
Can you Help with these Printers problems?
Printers
i purchased a lexmark printer X3650 on Nov 28,2008, i am...
Printers
print head moves but does not print
Printers
I have a Macbook Pro running windows XP Pro as a virtual...
Printers
How to print with stapling
Printers
I recently purchased an HP Photosmart C4400 series...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
