Question about ZoomTel V3 Router (55670000)
Internet access HI I have a PC connected to a lan port on the V3 with an address of 10.2.2.13. The V3 is also connected to an ethernet port on our network and has picked up an ip address. however when i try and use the internet I'm unsuccessful.
  • 3 more comments
  • grpeur Jan 03, 2008
    with a bit more investigating I can access the internet if I disable the firewall on the zoomtel v3. Obviously this needs to be enabled. Have you any idea what options need to be changed
    I've enabled all ports on outgoing connections but it still doesnt work.
    I've tried allowing everything in and everything out but i still cant access the internet. Is there anything else i can try
    no proxy server set up
    sorry to be a pain but i've reset the router a couple of times and tried allowing all ports and all traffice but it still doesnt work. None of the above tests worked, are there any low level tests i could try.
  • 556 Answers
A router by design is to provide a connection between two different networks -- separate networks with different IP address ranges. If this is a corporate network or someone else's network connection of a router may be undesirable or forbidden by their policies check before proceeding. To add additional devices to a wired network can often be achieved with a switch or a hub instead of a router which is far less complicated. You have indicated there is a DHCP server to supply network addresses on the existing network making the switch or hub approach potentially available. If however you are attempting to connect a router to a single port modem device to your internet service provider this may well be the correct answer. If you are attempting to separate portions of your operations for security reasons this may be part of a reasonable approach.
In general to access the internet you need a unique IP address belonging to the network to which you are attached to operate on that network. The address range of the LAN side of the attached router must be different than else where in the attached network. So the 10.2.2 network assuming a subnet mask of 255.255.255.0 must be unique to your router and not used elsewhere for other routers in the rest of your network. In addition you need gateway address and NAT (address translation) services to share the single internet address available to the internet in most home/small business environments from your router through the necessary routers all the way to the internet service provider's access point for your operation. You also need access to DNS servers to resolve textual names like fixya.com to IP addresses to route messages. Without any of the above your connection will not work. Some environments block direct access to the internet and require the use of proxy servers -- this could also be a requirement in your environment -- the configuration to access those can differ by facility and must be answered by the local administrative staff.
I hope the above helps
Posted on Jan 03, 2008
  • 6 more comments
  • Anonymous Jan 03, 2008
    Firewall is a somewhat generic term. From what I am gathering this device may be capable of blocking outbound port communication. A useful feature used appropriately. There are various ports used for specific internet activities. Blocking those ports can also block access to the internet. Port blocking can be done in either direction (more often inbound) is designed to allow opening the minimum number of holes in the firewall to allow required activities while preventing undesirable activities on other ports. A proxy server mentioned before can provide more intelligent monitoring of ports that a simple port blocking mechanism of a firewall. Now to identify the ports you need to open is a task I will provide some common ones to consider however depending on what you want to run/allow there may be more.
    I believe opening these only on the outbound side is required for most applications. Opening on the inbound side where required is riskier and is often only required if you have servers on your network.
    Port 80 is for standard http access though a browser and other things.
    Port 443 is required for secure http or https access to secure web sites
    ports 110 and 25 are defaults used for POP3 and SMTP mail access (only one mail option (imapi is another with different ports)) my ISP changed those and uses secure communications
    ports 20 and 21 are for FTP which some sites use to download files -- i'm not sure off the top of my head if you need both for requesting FTP transfers.
    If you host your own web server, FTP server, of mail server you may need to open (inbound this time) and or port forward ports to allow those services to be accessed from the internet.
    The registered port numbers appear in the following link however there are many optional ones that do not appear on this list.
    http://www.iana.org/assignments/port-num...
    This may help more.
    Sorry
    Port 53 is DNS another one you probably need to open.
    Try incoming too for 80, 443, 20, 21, and 53 your firewall may require both.
    Do you have a proxy server in your browser config using other ports -- that could also be the problem.
    on page 51 of your router's manual the following appears
    "By default, the firewall will allow only those packets to enter that
    you are likely to need; for example, in response to a request for a
    web page, or as part of a VoIP call you make. You may want to
    accept other, specific packets, perhaps to facilitate Internet gaming, or because you want people outside your network to access a server you have set up. You may want to prevent some users from accessing the Internet at all."
    In your case your changes have succeeded at making the latter happen.
    Did you change firewall settings from the factory settings and if so which ones on which pages -- you probably made a change you should not have? Depending on how much configuration you have done it may be best to reset the router to factory defaults, if we can figure out how and start again -- this time installing in what I will call phases.
    Configure the WAN side of the router with the necessary information to connect to your network. Things to include normally would be to accept a dynamic IP address or enter a static IP address, deal with any logon requirements like PPPoE or PPPoA and enter DNS servers or accept the server addresses dynamically. The list may vary and other items may be required. Once that is done before doing anything else try to access the internet. If it works the firewall configuration may already be set for the necessary access -- you indicated this worked before when you turned off the firewall and not now so there may be multiple configuration issues at this time. As you consider changes from the factory settings you are now aware that ports 80, 443, 20, 21, and 53 are important for internet access - to be careful changing those entries.
    When we are at this point carefully record any items you delete or changes you make == change one thing (or one page at a time) at a time and test to see if things still work. Undo the change if things are broken - test to assure things function correctly again. Try another change when things are working using the same process. This way you should catch yourself early when making a change that breaks things and can undo the damage by undoing the last recorded change.
    Your router is considerably more sophisticated that a home router. The process above moving slowly and deliberately toward a solution should keep you out of trouble. Trouble you will not be able to correct anyway.
    To test you can do the following -- you should probably clear your browser cache between tests just to make sure you do not get a cached page.
    www.ebay.com ----- (tests http (80) and dns (53))
    click signin ------------ (test https (443) and dns (53))
    ftp.microsoft.com --- (test ftp (20 or 21) and dns (53))
    ---------------------------- you might have to actually download
    ---------------------------- something to test both ftp ports.
    OK if it does not work and it it should lets go to the basics and review the WAN setup contents Who is the internet serviice provider and did they supply you clear requirement for connecting this router in terms of the items expected IP Address (static or dymanic), login like PPPoE, DNS addresses (static of dymanic) or should we look these up on their web site? Please provide your Internet Service Provider's name so I can assist.
    There are two basic diagnostic commands I tend to use --
    from the command prompt window
    one is ping (try to limit your pinging of machines that are not yours -- for me it is a courtesy item -- unless you really wonder if you have access or if the server at the other end is working to determine useful information)
    You can ping an IP address such as your router another machine on your network or a DNS address to see if you can get there
    ping 192.168.0.1
    ping 10.2.2.13
    another way to use ping test the DNS connection using a URL
    ping www.google.com
    a second command to assure the contents of a computer's adapter cards is ipconfig
    to show IP address, subnet mask and default gateway --
    ipconfig
    adds in DNS addresses and some other items
    ipconfig /all
    can tell if the DHCP has appropriately supplied information to the adapter configs if dynamic or allow a viewing of static information without opening the configuration
6ya staff
SOURCE:
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
How to hook up tv with internet hard wired to existing router with wireless connection to computer ip address on computer will not connect tv to internet help
Assuming that you have an "IP" TV, run an Ethernet cable from the TV to one of the LAN ports on the router.
Run another Ethernet cable from your computer to one of the other LAN ports on the router.
Both the TV and the computer should now have Internet access.
Do you have a third computer that has a "wireless" connection to the router?
Sep 26, 2010 | Belkin (F5D7230-4) Router (587009)
I don't know how to reinstall the linksys access point!!! Our wireless network that we made simply disappeared, so I'm trying to re-make one. However, when I tried that with a flash drive, it couldn't work...
T
o access the Access Points Setup, and the LAN IP address has not changed, then computer must have an IP address of 192.168.1.XXX. If the Access Point is plugged in via Ethernet to a Linksys Router and the computer is also connected a Linksys router via Ethernet, then the PC should already have a correct IP address (unless the LAN IP Address of the Router has been changed). If unsure, please assign the computer a Static IP Address so it will have an IP address in the same range as the Access Points IP Address.
If the Access Point is being connected to a hub/switch/router via Ethernet, then use the cable that was provided with Access Point. If the Access Point is being connected to the computer directly, then a Cross Over cable must be used. Cross over cables can be purchased at most electronic stores.
    Remember: When ever a change is made in the Setup of the Access Point, the Apply button must be used to save the settings to the Access Point.
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Access Point.
      Default IP addresses:
    • WAP11 v2.8 - 192.168.1.251
    • WAP54G v1.1 - 192.168.1.245
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Access Points password (The default password of a Linksys Access Point is admin) into the "Password" field.
May 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Need basic step-by-step instructions on how to install my router.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
I have linksys wireless-G 2.4Ghz broadband router connected to a pc. My wife bought a MAC and wants to get rid of the PC. Is the router compatible with a MAC? If so how do I download the software to set it...
Hi! Absolutely, the Router is OS independent. All you need is a computer with a properly configured Ethernet LAN adapter and a web browser to configure the Router. Any platform that supports Ethernet & TCP/IP is compatible with the router. You may need to provide additional hardware & software (i.e. Ethernet cards and/or software drivers) to ensure that all clients operate with the router.
By default of your mac computer it has already a buil-in LAN port same as your pc and it should be properly configured. just connect the cable from the mac lan port and the other end goes to your port 1 to 4 of the linksys router and it should give you an internet connection. if there is no internet access, pls check the ff:
1. Go to system preferences, network
2. It will pop up the network window
3. location set it to automatic
4. show - set it to built in ethernet
5. once you set it to built in on the lower portion it should set to tcp/ip and the ip address should show, once there is an ip address, you should get an internet connection, sabe or apply the settings
6. you are going to do the same thing if you are going to set the pc on a wireless connection.
if you have any querry pls feel to get in touch..
Aug 16, 2009 | Linksys Wireless-G Broadband Router
I have a new Macbook pro and when I attempt to set up a network I get a message that the connection is "timed out" I cannot seem to establish a network with either DLink or Lynksis Any suggestions?
By default of your mac computer it has already a buil-in LAN port same as other pc and it should be properly configured. just connect the cable from the mac lan port and the other end goes to your port 1 to 4 of the linksys or dlink router and it should give you an internet connection. if there is no internet access, pls check the ff:
Aug 16, 2009 | D-Link DIR-625 (790069292637) Wireless...
Access my lan from the WAN
I assume you want to log into your pc from another pc outside your lan. To do this you need to forward port 3389 to your pc.
  1. Make sure your pc (the one you want to connect to) has a static ip address. Also, it should have a password on the windows account you use.
  2. In the router, forward port 3389 (tcp) to the ip address of the pc.
  3. If you do this correctly, you can go to any pc outside your lan, and use remote desktop connection to connect. When you start the remote desktop connection, put in the wan ip address of your lan. If you did the port forwarding correctly, you will be asked for a user name and password. Put in the username and password for your user account on the lan pc and voila! - you are logged into your lan pc remotely.
Let me know if this works, or if you need some more help.
Aug 08, 2009 | Zhone 6211-I3-200 Router
D-Link DES1008D 8 port fast ethernet desktop switch
By using it, of course you have this items to connect it with internet:
  1. UTP Wire with Connectors at end each PC or Client Workstation.
  2. Make sure every PC or Client Workstation have its own LAN Card.
  3. To connect on the internet is to know what is IP Address, Gateway Address & DNS Server Address settings on your LAN connection.
  4. Lastly, It should have internet provider in your place.
Jul 29, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Please clarify what you mean by ''Connect with an ethernet cable''
Ethernet cable means CAT5 or UTP for others or LAN cable. The connection should be LAN port of your computer to LAN1 of your router.
And you can connect also the internet cable usually ethernet cable from your internet provider directly to (ethernet cable)WAN port of your router to get signal from your internet provider.
Also if you get this message, this could also means you still don't set up or configure the router's settings to communicate when your LAN and router. They must see each other to access the router's utility webpage.
Regards
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
No connection via Ethernet between Zyxel P-660HW-D1 and PC
Hi Friend,
Before Connecting your internet we must check in ur system.
1.Go to Start---->Run------>type cmd----->in the black screen type ping 127.0.0.1
2.check wither its getting reply or request
3.If u are getting reply then ur system is perfect i.e., your NIC Card is installed properly.
4.check wither any proxy is enabled in the LAN settings.
go to browser--->tools---->internet options(Options)----->Connection--->Lan Setting--->there should noy be any tick mark in the boxes
Now we can check the connectivity,
1.Connect the PC from the Router Lan Port and the modem connectivity to the Wan Port of the Router.
2.Assign the Ip address as obtain ip address automatically
Right click networkplaces--->properties--->Lan Connection Properties---->double click the internet protocol(Tcp/IP).In the next box u must select the Obtain Ip address automatically
3.Now u switch on the modem after 30 sec switch on the Router.
4. Launch your web browser.
5 Type "192.168.1.1" as the URL.
6For administrator access enter the default admin password 1234 to configure the wizards
and the advanced features.
7 Click Login to proceed to a screen asking you to change your password or click Cancel
to revert to the default password.
8 If you entered the admin password, it is highly recommended you change the default
admin password! Enter a new password between 1 and 30 characters, retype it to
9.Then u can configure the ip address
Regards,
Ayyasam
May 29, 2009 | Zyxel P660HW-D1 Router
Open Questions:
See all ZoomTel V3 Router (55670000) Questions
ZoomTel V3 Router (55670000) Logo
125 people viewed this question
Top Zoom Computers & Internet Experts
Paul Castley
Paul Castley
Prashant M
Prashant M
Ekse
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
