Question about DXG Technology DXG-506V DV Digital Camcorder
MP3 Problems The music will show up when plugged into a computer but not when the camera is just on MP3 mode. What am I doing wrong?
The songs need to be in .mp3 format. But...I can see mine now, but they play way too slow...almost unrecognizable.
Posted on Jan 04, 2008
Whow come my rca th1100a mp3 player shows that there is music on it while plugged into computer, but shows that it's empty when I unplug it ?hat's your problem?
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Sep 19, 2012 | RCA Audio Players & Recorders
Trying to syn music to my mp3 insignia
It may not be anything you are doing wrong. You will have to see how your player is seen buy your computer. Go to your control panel -> System -> device manager --> Look for your player there, does it show up as a Portable Device? NOTE: The player should show up on the Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode.)
It should sync with Media player if it shows up as a Portable device - but if it shows up as a Mass storage device all you have to do is drag and drop what you want into the right folder on the player.
Apr 29, 2010 | Insignia Kix MP3 Player
Whn my player is plugged up to computer I can see
the music is not in the correct folder for the mp3 to read or.
the music is in a format that your mp3 doesn't comply with.
Nov 29, 2009 | Sony NW-E105 MP3 Player
Copied files, not to be found once mp3 player is turned off.
Plug in your mp3 player and remove any music or what ever you have on it then open explorer and click on tools and then folder options and then view click on don't show hidden files hit okay... Then check your mp3 player for a USB mode make it mtp or msc...Mtp makes it a mp3 player Msc makes it a disk drive it doesn't matter which now start Dragging and dropping your music in to your mp3 player.................When you put files which are hidden in the player the can't be seen by the player
Feb 28, 2009 | SanDisk Sansa e260 MP3 Player
How do you reformat the sansa E260?
There are several possibilities.
1) The songs that you loaded may not be compatible with the player - iTunes files, for instance.
2) The songs that you downloaded may not have transfer rights - i.e.: they will play fine on a computer, but they will not play on an mp3 player.
The solution to the above two possibilities would be to download songs that are in mp3 format only. They do not have strings, stipulations, headaches, etc. attached to them.
Possibility #3 is that your mp3 player is in the wrong USB Mode. Songs that show up in MSC mode do not show up in MTP mode, and vice versa. To change this, go into your Sansa player's settings menu and change the USB Mode.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa e260 MP3 Player
Removing music
Plug your mp3 player into the computer using a USB cable. Make sure you only have the one MP3 player plugged in, and no flash drives or cameras, etc.
There may be a button on your MP3 player that sets the mode to MTP or USB or Ready Mode. Make sure the setting is at MTP.
Open My Computer from the start menu. There should be a list of drives and document folders. You should see a drive labeled "removable storage" or "_____-Audio Player", (_____ may be your name or the name of the mp3 player).
Double click that drive. You may now see something to the effect of "SD/MMC Card" and or "Audio Player" or the name of your MP3 Player. You may also see files that say "Music" or even the music files themselves.
Double click on "Audio Player" if you do not have music on your SD/MMC Card (or if you just don't have one in your MP3 player).
If there is no "Audio Player" file, click on "Music" or the next best looking folder (it won't harm your computer or MP3 player if you look in all the folders). This should open up into Music files or a folder labeled Music. Double click this folder. Inside you should see all the music (or videos) that is on the MP3 player. Delete the music folders and files, but be careful not to delete anything else. The folders should be labeled by Artists, then Albums, then finally the actual music files. Delete all the Artists, albums, etc, to remove the music.
If you can't find the music files using my instructions, look in the folders of your MP3 player until you find them. Also, remember to have your MP3 player set to MTP mode if it is available.
Hope this helps.
Jun 07, 2008 | GPX MW3826 MP3 Player
SanDisk Sansa e250
Well the SONGS folder might be hidden [happened to me]
Steps to see hidden folders:
-My computer
-Tools
-Folder options
-View
-Show hidden files and folders
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
Music will not show up on player after download
two suggestions:
put player in msc mode by going to the settings menu and choosing USB mode, then change to MSC
then plug in and open the player in My Computer menu
if you do not see songs on the player, back out and format player at the drive letter prompt, then add songs either manually, drag and drop to the player (not the music folder!)
or sync the songs with windows media player 10 or 11
Oct 19, 2007 | SanDisk Sansa e250 MP3 Player
Mp3 player has no music
The player has a Recorder Mode and an MP3 mode. The player defaults to recorder mode for some reason, this is probably why you cannot see the songs. To switch to MP3 mode you have to hold down the MODE button for more than 2 seconds. Then you should be able to see the songs.
Apr 23, 2007 | Sony NW-E507 MP3 Player
Restarting
just keep it on the mode to put music on and when you want to delete music or videos just right clic on the song and look for the word delete and clic it
Apr 05, 2007 | SanDisk Sansa e250 MP3 Player
DXG Technology DXG-506V DV Digital Camcorder Logo
43 people viewed this question
Top DXG Technology Video Cameras Experts
SHARCNET-USA
SHARCNET-USA
Hjalmer Lamminen
Hjalmer Lamminen
Jose Ma DM.
Jose Ma DM.
Are you a DXG Technology Video Camera Expert? Answer questions, earn points and help others
