Question about Fossil CH2332 Wrist Watch
Ch2332 how do i get the pins out of the wrist band
    Scholar:
  • 64 Answers
Believe it or not there is a special way/tool used to take the pins out. I had a similar problem with my watch and had to take it to a jeweler to get it done properly. I fumbled with for a while and finally just took it to a professional. You will do more damage or may even break it if you try to do it yourself. Maybe take it back to the store where you purchased it and have them do it for you free of charge depending on how long ago you got it.
Posted on Jan 03, 2008
Removing wrist band
You can remove any watchband using a pocket knife trying to get between the back side of the band and the watch. Gently pry sideways until you see the spring-loaded end coming out. Flex the band back from the watch as you do this action.
Nov 28, 2013 | Fossil CH2332 Wrist Watch
Wrist band pins slip off easily
put a spot of super glue on the end of the pin befor you push them in
Jun 01, 2013 | Seiko SNP022P1 Wrist Watch for Men
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
Pins keep popping out when watch band gets snagged. What size are the pins for watch band?
mcdevito75 here, These pins may be a bit worn in the band of your watch, if so, you"d have to order a kit with various size pins for replacement. BEST BET, look for a small watch repair shop to fit new pins in the band.
Jul 12, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
It's too small on my wrist I have the extra bands but I don't know how to add them
you will need sharp needle nose pliers and a small ering pin (the part that goes thru the ear) use your needle nose pliers and grabing the ear pin pushe the pin that holds one of your wrist band then finish pulling the pin with the needle nose pliers all the way add the extra band and insert the pin with your fingers first then finish with pliers
Oct 26, 2009 | Kenneth Cole KC3315 Wrist Watch
Skagen 596XLTXM Titanium Mens Watch
good morning ! you need a puncher pin and anvil to remove the pin on your watch band punch or push the pin use the puncher pin according to the arrow sign,full the pin to remove,and fush to fix again,do it carefully,thank you ! god bless .
Aug 27, 2008 | Skagen 355LGSC Wrist Watch
Band
If it not obvious how the hinge pins are removed, then I suggest that you go to a watch shop to do it for you.
Apr 15, 2008 | Fossil CH2332 Wrist Watch
User Manual - Fossil CH2332 Wrist Watch
go to fossil.com click on customer support that is where the manuals are hope this helps
Apr 04, 2008 | Fossil CH2332 Wrist Watch
Shortening the Length of a Metal Wrist Band
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
Nov 06, 2007 | Kenneth Cole KC3289 Wrist Watch
The Pin which holds the watch band in place keeps coming out
you should be able to contact timex and order the pins directly
Apr 02, 2007 | Timex Ironman 30 Lap 53952 Wrist Watch
Fossil CH2332 Wrist Watch Logo
137 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
john h
Are you a Fossil Watch Expert? Answer questions, earn points and help others
