Question about HP PhotoSmart 7550 InkJet Printer
HP PhotoSmart 7550 printer - how to get the top off?
How do I get the top cover off? (simple - but I cannot find the snaps or screws)
  • 2 more comments
  • ames458 Feb 27, 2008
    Me too. How do you get it off?
  • Anonymous Mar 14, 2014
    how do i replace top cover on hp photosmart 2610xi printer
There are three special types of screws on the back of the printer. Using a TORK BIT T-10 screw driver remove the two top screws that holds the gray top on. There are several snap connections on the bottom edge of the gray case.
Posted on Mar 24, 2008
I want to connect my Dell inspiron 1525 laptop (basic vista)to HP 7550 printer. What type of usb cord do I need, and are drivers available online?
Assuming this is a Photosmart 7550 printer and not the 7550 Plotter, this is what you will need for connectivity. To connect printer to PC, you will need a standard USB A/B cable... one side is a male A connector and the other one a male B connector. As far as the drivers are concerned, you will not need to download any. Vista already has a compatible driver for your HP Photosmart 7550. HP recommends selecting the drivers for the Deskjet 5550 when installing your Photosmart 7550.
Sep 26, 2009 | Dell Inspiron 1525 Laptop
Hp photosmart 7550 says carriage is stuck
print cartrigeis cradle is stuck clear jam then press ok in hp photosmart 7550.
Apr 04, 2009 | HP PhotoSmart 7550 InkJet Printer
I have an HP Photosmart 7550 printer. How can I
First plug the printer to the computer .
Click on the "Start" menu button which is located on bottom left hand corner of your screen.
Click on the control panel icon.
Look for the printer/fax icon in the control panel window. Double click on the printer icon.
Find the icon for your printer in the opened window and right click on the icon. Now click on the "Preferences" option.
Look for the menu box pop up with tabs near the top of the box. Click on the "Services" tab.
Click on "Service this device." You will find the button on the Services menu that you just activated.
Click on the estimated ink level tab and a graphic will appear indicating how much ink is left in the cartridge.
Mar 08, 2009 | HP PhotoSmart 7550 InkJet Printer
Cradle slamming and strip un-hooked
This is the encoder strip please get it fixed in service center or if the printer is in warranty get it replaced.
May 17, 2008 | HP PhotoSmart 7550 InkJet Printer
Cartridge cradle is stuck
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
HP PhotoSmart 7550 InkJet Printer Logo
176 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
