Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Canon EOS300D Mirror Problem
Having a problem with my EOS 300D- when I take a picture the mirror goes up but doesn't come down. The only way I can take another picture is to remove the lens and flip the mirror down with my finger- which works but is obviously not ideal. The firmware I have is 1.1.1- wondering if that would make any difference. Other than that everything is working fine. Cheers.
  • arielstarr Jan 10, 2008
    Yeah, I know it's not ideal, but I'm looking at repair cost the same as the price of the camera when technically it is still capable of taking photos. This model doesn't have a "mirror lock up" feature and if it did I believe you are supposed to be able to relsease the mirror by pressing the shutter release again and this doesn't work.
  • 42 Answers
This is not exactly concerning the mirror but the logical sequence is controlled by a wheel at the bottom that could be defective.
Mirror-lock-up function is performed not mechanically but electronically through the mentioned sequence-control wheel.
Posted on Feb 12, 2008
  • 35 Answers
Never, never touch the inside of the camera with your finger! Beside all other bad things this will void your warranty if discovered.
Your camera is either defective and needs service, or you have selected the "Mirror lock up" feature which is intended for cleaning the sensor (with special tool)
Posted on Jan 09, 2008
Eos 300d when used in AV mode pictures come out black
Sounds like a problem with the aperture unit in the lens
Jun 08, 2012 | Canon Digital Rebel / EOS-300D Digital...
Canon 40d will not take pictures
1) CF card in camera? Won't shoot without one
2) Does mirror go up?
3) Canon had a run of bad motors for this model - if mirror does not go up, then it is the mirror motor. If mirror goes up, shutter will not fire, press release again then the mirror goes down, the shutter motor is bad (same model motor). If mirror goes up, shutter fires, both blades travel together/no exposure, probably the shutter is bad.
May 07, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
Canon EOS 300D which is over Exposing
try adjusting the exposure levels set default zero to negatives untill your sure of the right exposure that you want....hope this helps
Nov 25, 2009 | Canon Digital Rebel / EOS-300D Digital...
My EOS 300d is not recognized by computer
have you tried to change the USB cable, or USB plug?
if did not work, try uninstalling the drivers & reinstaling them again (also update the firmware of you camera)
hope this will work
Aug 21, 2009 | Canon Digital Rebel / EOS-300D Digital...
My EOS 300d blank images
That problem is normally associated with having a too high shutter speed when using flash. If it happens in any mode, with or without flash you may have a shutter blind issue.
Test the camera at various shutter speeds and compare the results. If this black area is consistant across different shutter speeds, send it in for repair. It is most likely the shutter curtain not making a pass across the sensor fast enough, still obscuring the sensor when a photo was taken.
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 300D Loose primary mirror
Absolutely. Glue away. These mirrors of course in no way effect image quality, but you still want to be careful with the glue, and make sure the mirror stays aligned so it's free to flip up.
Hope this helps
Jul 06, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon 300d autofocus problem
Have you choose a correct "Focusing Point" by pressing the right outmost button on the rear of the body, just above the CF card compartment door?
Feb 23, 2008 | Canon Digital Rebel / EOS-300D Digital...
Eos 300D. THE FLASH DOESN`T POP UP
there is a setting that tells the camera to use flash or not to. refer to manual. its simple to remedy.
good luck
mark
Dec 08, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Digital Rebel 300D
id recommend taking it to the canon dealers..this seems like a problem with the software
Nov 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
98 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
