Home | Dell | E172FP (Black) 17 in. Flat Panel LCD Monitor | My monitor is blank and...
Dell E172FP  17 in. Flat Panel LCD Monitor
Problem for Dell E172FP (Black) 17 in. Flat Panel LCD Monitor
My monitor is blank and the light flashes green
By elli9699 on Oct 30, 2009
my monitor is blank and the light flashes green and amber. i've tried checking the plugs, all is plugged in ok... driving me crazy
Comments:
Oct 30, 2009
- no it's not doing anything.. the screen is totally black but the light indicator just flashes green and amber
Oct 30, 2009
Oct 30, 2009
- so how do i check the vga card? whatever that is.. somebody told me that before that maybe it's the video card..
Oct 30, 2009
Clarification Request
Posted by halbrook on Oct 30, 2009
if your monitor displays the white text while booting up but flashes green and amber after loading OS, your screen resolution settings is higher than your monitor can handle. let me know if that is the case and what OS you are using.
Best Solution
posted on Oct 30, 2009
Very Helpful)
lserni
Rank: Guru  Computer Hardware  Expert
Rating: 89%, 72 votes
Verify monitor operation by UNplugging it from the computer and turning it on. A "Self Test Screen" shall appear (if it doesn't, the monitor is faulty and must be repaired).
Assuming it worked, plug it again and turn it on. After half a minute or so, turn the computer on. You should be able to see at least the BIOS POST screen: if you don't, there could be something wrong in the computer video board (maybe misconfigured, or set to output to a different, possibly internal, head - I saw it once with a Matrox VGA). Refer to the VGA manual for that.
If the POST screen appears, the problem is perforce in the OS VGA configuration. Assuming it's Windows, you can get into the safe mode boot screen by pressing the F8 key at boot, and once booted, access the video resolution configuration from the Control Panel. Set it back to something surely working, in your case 1024x768, and work it up from there.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
hichama9
Rating: 90%, 29 votes
Hello my friend,
This can happen when the plug is broken or VGA card is faulty.
first, i suggest to test the screen on another computer: if it works correctly, then you will need to change the VGA card but if it doesn't work i will say that the Screen is defective and need an RMA.
Best Regards,
Was this helpful?
Yes
No
Popular Solutions for Dell E172FP 17 in. Flat Panel
Questions and Unsolved Problems for Dell E172FP 17 in. Flat Panel
Do you recommend Dell E172FP (Black) 17 in. Flat Panel LCD Monitor?
Answer
Answer
I have a delll E172fpb monitor that only displays a solid white screen is there a solution to the... (More)
Answer
I have a Dell flat screen monitor, model E172FPB that has started displaying the Dell monitor menu... (More)
Answer
All functions work, but there is a graphic pciture of a lock right i nthe center of the screen and... (More)
Answer
I have used the monitor on different computers with the same results - the screen shows for 2... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell E172FP 17 in. Flat Panel...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
