Question about Asrock AM2NF3-VSTA (4711140874470) Motherboard
Power boot up problems
I seem to have a problem that quite a few people have mentioned (but no working solution has been found that I can find).
After plugging everything in and then flicking the power switch on my power supply (not on the PC box) all the fans start up but it seems like nobody is at home. No beeps and only one green light on the box that doesn't flash or flicker. Monitor doesn't register anything and no POST or bios information shows up.
My specs are:
Asrock AM2NF3-VSTA Motherboard
AMD Athlon 64 X2 4600+ Windsor 2.4GHz
ELSA GLADIAC 776 GT AGP 256MB (7600 GT)
1GB PGI DDR2-667 RAM (667MHz)
1GB DDR2 PC2-6400 Elixir (800MHz)
Western Digital 160GB HHD
ENERMAX EG365P-VE FMA 1.3 ATX12V 350W Power Supply
I bought the board because my AGP is still strong enough for what I need but I wanted to start using a 64 bit processor.
I've tried switching RAM sticks and slots and using only one chip and but no change. The power seems to start up as soon as the PS is switched on. Holding down the power button on the box does't shut it down and the reset button doesn't seem to have any effect either.
Any help would be appreciated!
  • Paul Hallett Jan 03, 2008
    Unfortunately I can't even get into bios :-( The screen stays blank during the whole process (light on monitor doesn't change from yellow to green so no signal seems to be getting sent by the graphics card)
Booting form cd is not respeding
Posted on Apr 26, 2008
  • 2,427 Answers
Check your bios for your power failure setting
it may be set to instant on of power failure
you need to set that to off
Posted on Jan 02, 2008
6ya staff
SOURCE:
Our server hp proliant ml 150 g2 was working with 4 gb RAM. BUT few days before, there was a problem in our ups system. so its turned off. after that, when i started it, its stuck on pre post startup...
Try the same steps but not in that order. The problem seems to be appearing during booting.
1.After boot-up try powering on the external drive
2.Shut down the computer from the start menu
3.Then power off the external drive
4.Hopefully on the next boot-up problem will be solved
Apr 07, 2017 | HP ProLiant ML150 G2 Server
Compaq presario 2199us notebook does not boot
Hi Krishna. Could be that the processor's cooling fan is no longer functioning and then the processor instantly overheats and everything STOPS !!! Could be the RAM memory chips not in good state anymore .....Could be that (while it tries to determine what hard drive is in there) the hard drive is BAD and cannot be identified... that would also just STOP everything. It really is quite a few things that could cause that
Jul 06, 2009 | HP Compaq Presario 2200 Notebook
Trying to find parental code so i can watch a movie on it?
I too have the Ramone DVD player and had quite a surprise the first time I popped in a PG rated DVD.
There is no mention of a parental code, turning it on or off or ANYTHING in the manual.
On another website, I found the code 1369, which seems to work. I taped it to the bottom of the really cool remote. Still found nowhere to change it, etc. Least you can watch your movie!
Mar 30, 2009 | Disney Cars Ramone DVD Player
My Soyo DYLT032 has power but no picture or sound
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Dec 28, 2008 | Soyo DYLT032C 32 in. LCD Television
Periodic Boot-up Problems with Dell Latitude D600
Well I had the same problem with my Dell Latitude D600. I tried many batteries, fully charged, partially charged and even i tried scenarios with AC Power On or Off. Nothing really seemed to work as my laptop was both hot and cold. I noticed this problem was coming specially when laptop is cold.
The Solution is found is, when i have this problem, i press the power button and then move the rotate the laptop, so that its screen touches the desk and keybord is upright verticle, i know it sounds ODD, but it really made my life so easier as now this problem doesnt haunt me.  and it will boot on first, second or third go.
Normal Laptop Condition with keybord down and LCD Open
                     /                     /      / lcd
__________/
You need to move the laptop in one of the following if it is having boot problem again
       \               /          \            /            \         /  keybrd  \      /  lcd                \   /                 \/
or put the lcd down flat while keeping the keyboard in the same position as above.
I m sorry the above illustrations are pretty rough but hope u understand what i mean :)
Aug 18, 2008 | Dell Latitude D600 Notebook
Saeco Primea RIng - Cycle interrupted - only a few drops come out
Hi
Have you found a solution yet?....we have the exact same problem....
Mar 16, 2008 | Kitchen Ranges
Acer Aspire 4520 display off suddenly without warning
please clarify this sequence of events: "on AC power,it seems to be working fine. But the problem occurs when I try restart it on the next morning"... was it restarted next morning on AC power or battery...which one?
Aug 26, 2007 | Acer Aspire 5100-5033 Notebook
Startup issue
Sounds like a problem in the power supply section that will need component-level electronic troubleshooting. If it's under warranty and less than 30-60 days, I would suggest an exchange. If not, I would call the number in the manual for help.
Jan 01, 2007 | Apple Cinema HD 30" LCD Monitor
Asrock AM2NF3-VSTA (4711140874470) Motherboard Logo
369 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
