SOURCE: oven panel
First try unplugging or turning off the breaker and see what happens. If that fixes it your good to go if not you probably need a control board. Some of the boards have a fuse but no one changes it as it is soldered onto the control board.
SOURCE: Jenn -Aire self cleaning
I turned the power off on the breaker for two minutes. When I turned it back on, the range worked again.
SOURCE: I can't get the oven temp to set on my Jenn Aire eletric range
I was looking to see what kinds of problems the JES9860 electric slide in was having. I am not sure if this is your model, but if you go to the Jenn Air site, you can find your model, click on it, scroll to the bottom of the page and click on SPECS & LITERATURE, its to the right of "features". You should be able to Download the manual on the guide there and that shouldhelp you to set the temp correctly. If anyone has any feedback of the JES9860 as far as if they like it, hate it or otherwise, can you please post. I'm getting ready to make a huge committment. Thanks much and good luck.
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
SOURCE: Our jenn air model js9860aab control panel buttons
no.. u must replace the touch pad assrmbly that whole unit.... i think u have a jds9860aab i believe... the part number u would need would be 74005750 it is for sale through sears at $272.00... u might need service.. u can take a look at part at repairclinic.com just type that part number in. ohhh also i believe this is a backordered part so most companies would prob take 2-3 weeks to get soo hope this helps..
